Ask an Expert Forum Help to find a replacement switch for a nail gun
  • Replies 18 replies
  • Subscribers 334 subscribers
  • Views 2635 views
See a helpful answer?
Donzella
Donzella over 1 year ago
  • Salve e l'interruttore di una spara chiodi di provenienza inglese, sviluppato su Amazon contattato il servizio clienti e non sanno come aiutarmi. image
    Jan Cumps over 1 year ago +2
    That isn't a thermistor
    shabaz over 1 year ago in reply to Donzella +2 suggested
    Hi, This should be a separate topic because the original topic creator is discussing something different. For your switch, you should measure the dimensions, and then check farnell.co.uk (or your country…
  • cstanton
    cstanton over 1 year ago in reply to kmikemoo +2
    kmikemoo said: OP posted that he found the switch on two unrelated threads. Which I (hopefully) merged into this one.
    0 Jan Cumps over 1 year ago
  • acdc90
    0 acdc90 over 1 year ago
    did the switch measure ok before someone tried to get the switch apart..
     Is this the original fault
  • Donzella
    0 Donzella over 1 year ago in reply to acdc90
    Buongiorno a tutti voi, l'interruttore l'ho smontato io in quanto si era rotto la leva nera che vedete nera .
  • Donzella
    0 Donzella over 1 year ago in reply to Jan Cumps
    Non so cosa e' il termistore
    0 shabaz over 1 year ago in reply to Donzella
    For your switch, you should measure the dimensions, and then check farnell.co.uk (or your country specific farnell site) for a switch of approximately similar size. It looks like there are three metal contacts in your photo, so that would be a "SPDT" switch although if only two connections are made to wires, then a "SPST" switch would also be compatible. It's called a SPDT or SPST "slide switch". You need to check that the replacement supports 125VAC 3A minimum, and  125VDC 0.5A minimum (higher values are fine).
  • Donzella
    0 Donzella over 1 year ago in reply to shabaz
    Grazie vi faro sapere.
  • acdc90
    +1 acdc90 over 1 year ago
    IF YOU know dimensions, try this
    https://au.element14.com/w/c/switches-relays/switches/slide-switches?st=SLIDE+SWITCH+&orientation=vertical
    it does not matter if spdt or dpdt
    is there only 2 wires soldered to it
  • Donzella
    Si
  • Donzella
    Grazie ho visitato il sito, si avvicina molto alla mia richiesta.
  • Donzella
    Chiedo a loro nel caso
