Ask an Expert Forum How do you choose soldering iron tip size and solder wire diameter?
  • Replies 29 replies
  • Subscribers 338 subscribers
  • Views 11270 views
  • solder breadbox
See a helpful answer?
HKPhysicist
HKPhysicist over 1 year ago
Hello Friends and E/E Engineers,
I have bought this solder bread box for my new project.  This is my first time to solder my own circuit.
I think it is the universal standard 0.1" pitch holes board.
According to your precious experiences, what soldering iron tip size and soldering wire diameter do you choose?  Primarily, I do pass-though-hole parts plus few SMD. Pray
I did try a soldering iron tip in 1mm diameter and solder wire in 0.8mm diameter on this board but my solder joints seem too fat Penguin , not as slim as theirs shown here:
https://www.adafruit.com/product/5900
    shabaz over 1 year ago +5
    Names of some typical tip shapes to help with the terminology (since some of it may become lost in translation for non-English-language readers).
  • phoenixcomm
    phoenixcomm over 1 year ago +4 suggested
    HKPhysicist Ok FORGET EVERYTHING YOU KNOW, THINK YOU KNOW. Go to my Soldering School blogs and READ ALL POSTS! Then Download from the web NASA-STD-8739.3, NASA Training - Student Workbook for Hand…
    Jan Cumps over 1 year ago +3
    For this type of perfboard, the standard tip of most irons will do. I think that your joint quality is either due to: - wrong temperature - wrong technique - not enough flux Questions: - What…
  • anniel747
    0 anniel747 over 1 year ago in reply to HKPhysicist
    [deleted]
    0 Jan Cumps over 1 year ago in reply to anniel747
    I can do 0402 repeatable, with magnification glasses. Not comfortably though.
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to anniel747
    Those flux condensed between the joints` gaps!  Are there any tool to remove it?  Cotton stick cannot remove them.
  • colporteur
    0 colporteur over 1 year ago
    Everyone that has practiced the black art of soldering will have a "tip" you can use. It is skill acquired by practice and the experience earned best gives you the knowledge to make it work for you.
    I use one tip for my work, long conical. The pencil end allows me to get into close spaces and moving up the tip adds more surface area if extra heat is needed. I have a welder soldering station I earned in a RoadTest https://www.element14.com/community/roadTests/2139/l/weller-soldering-station-wt-series . If I had to start over, I would invest the money in such a good iron.
    The iron, the solder and the material being soldering all come into play for good solder joints. The recommendation to use documented resources is not such a bad idea. It is difficult without hand-ons guidance to perfect a technique and avoid pitfalls.
    I like your plan of using soldering projects to expose yourself. My first solder project was a terminal board with rows of vertical spade lugs. The task was to create series and parallel point to point circuits using solid 26 gauge wire. Burnt wire, overheated terminals and cold solder joints were all part of the learning experience. Soldering PCB came much later.
    Good luck on your journey.
    Here are the tips I use: /challenges-projects/project14/w/documents/27443/project14-winners-announcement-auto-hacks?CommentId=9494dbaa-1f17-47fa-b2d5-a54d8489c2d4
    Leadfree solder: Sn99.3 Cu 0.7, 0.6 and 0.38 mm
    A lot of flux. Paste for big work, a pen for single component rework.
    350° usually, 380 when needed. I stray away from that when a board requires more or less heat.
  • anniel747
    [deleted]
  • HKPhysicist
    I see.
    Let me try with my worn out Colgate. Laughing
  • mp2100
    0 mp2100 over 1 year ago in reply to HKPhysicist
    thank you for these honest photos. I have done soldering just like that.  From that experience, I think you need to heat the pins and pads before applying the solder.  In addition to deciding solder size and tip size.
  • SensoredHacker0
    0 SensoredHacker0 over 1 year ago in reply to HKPhysicist
    only if you're slow. ( no offense )
    if you're not comfortable at that temp, go lower.
  • SensoredHacker0
    some of those connections look very good!
    Its a delicate skill to get the solder around the whole pad, without adding too much solder.
    the pictures are a bit blurry, but it appears you have dimpling, which is where the solder has flowed, and sunk after heat was removed.
    this happens when the parts, metal pads, pins, get too hot for too long.
    as for clean up, a toothbrush, and anhydrous ethyl alcohol work well.
