Ask an Expert Forum I'm fixing a broken Nexus 10 Tablet, and I need a part
  • Replies 12 replies
  • Subscribers 334 subscribers
  • Views 2003 views
  • nexus 10
  • 50-pin zif connector
  • ribbon connector
  • digitiser ribbon cable
See a helpful answer?
stanto
stanto over 1 year ago
Specifically, my dad already had a go at fixing the Nexus 10, and he was more than a little heavy handed, and did the typical thing, and broke this rather annoying clip:
The ribbon cable still seats in it, because the white component is there, it's the black lever/clamp that's snapped off; and as anyone who has experience with this, it's pretty much written off because you can't put it back, and you really can't (unless you're super lucky) put pressure back on it.
Annoyingly this affects the digitiser, so the device isn't a full write-off, but it no longer has a useful touch screen, and I'd like it to be, so that I can use it as an IoT/in house front-end for home automation stuff local to my network.
I think it's a 0.5mm pitch, 50 pin FPC/FFC ZIF connector, and I'm having difficulty finding it online.
If anyone could advise on where I can buy this so that I can replace it myself (I have solder paste, hot air station, etc.) I'd appreciate it. Or I'm open to alternative whacky ideas of fixing this sort of clamp for the fun of it.
Thanks for reading.
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to anniel747 +2
    yup Kapton great stuff!! and when you put it on it says on! You know 3m Scotch tapes are used in aerospace to hold panels on! LOL
  • acdc90
    acdc90 over 1 year ago +1 suggested
    Hello from the first discription is the black piece come off or has 1 corner broken off of the black piece what about some more photos like with the cable removed photo from front and rear and…
  • anniel747
    anniel747 over 1 year ago in reply to stanto +1
    LCD diffusers of different thickness are kept in stock for urgent repairs and always worked out fine. You need to use real Kapton not chinese polyimide tape.
  • anniel747
    0 anniel747 over 1 year ago
    Quick fix is a fine plastic strip cut to size and Kapton tape.
  • acdc90
    0 acdc90 over 1 year ago
    Hello
    and photo of cable next to socket is the copper side up or down side
    if carefull you can reasemble and use tape to hold in place
    i am thinking molex connector 5051105091
    which i found using the digikey website search
    then copy into element14 and they have it
  • stanto
    0 stanto over 1 year ago in reply to anniel747
    Thanks for the suggestion, unfortunately, that's what I already attempted and alluded to when I said:
    Doesn't quite cut it! Which is why I made the thread to help find the part to replace. Slight smile
  • stanto
    0 stanto over 1 year ago in reply to acdc90
    Ah I'm not a business (or from where Farnell's known as element14), so it'd have to be CPC or somewhere else for me to order it.
    Oh, that almost looks like it.
    Ah, I will see if I can get photo's of it, but the photo' in the thread so far was from ifixit: https://www.ifixit.com/Parts/Nexus_10 and their guides: https://www.ifixit.com/Guide/Nexus+10+Display+Replacement/62771
    Doesn't appear to apply the right amount of pressure to hold it against the contacts, unfortunately. Thank you.
  • anniel747
    0 anniel747 over 1 year ago in reply to stanto
  • anniel747
    0 anniel747 over 1 year ago in reply to acdc90
    Usually the contacts are on opposite side of the actuator.
  • rsc
    0 rsc over 1 year ago
    You could find another broken tablet and take the part you need from it.  This will start you on your journey of collecting other people's broken things - because they might have parts you'll need later to build more better stuff.  If you count my basement, shed, and garage, plus two labs at work, I've probably accumulated 1000 square feet of other people's broken things.
    0 DAB over 1 year ago in reply to rsc
    Yes, acquiring broken equipment is a sickness, but you have so much fun seeing what's inside.
  • phoenixcomm
    0 phoenixcomm over 1 year ago in reply to anniel747
  • anniel747
    0 anniel747 over 1 year ago in reply to phoenixcomm
    phoenixcomm On some jobs I have seen chinese copy that smells like cat urine and ends rolls up while unsticking.
