Ask an Expert Forum How does 569 relate to 5.6pF on an MLCC through hole capacitor, I understand 101 or 104 but why 569?
  • Replies 12 replies
  • Subscribers 335 subscribers
  • Views 2049 views
See a helpful answer?
davebullockmbe
davebullockmbe over 1 year ago
Hi I just received what purport to be some through hole 5.6pF MLCC's marked 569, how does this relate to the value?
I understand MLCC's marked 101, 102, 473 as the last number is the multiplier (how many zeroes) but xx9?
Whilst an internet can decipher the value it offers no explanation of the value numbering origin for such low value MLCC's
Please explain.
Dave
  • davebullockmbe
    davebullockmbe over 1 year ago in reply to michaelkellett +3
    Ha! Mystery solved...the xx9 (9) means there is NO multiplier and infers that the value is BELOW 10pF. I just found this chart (below) Once the value increases above 9.1pF the familiar 100 appears…
  • anniel747
    anniel747 over 1 year ago in reply to davebullockmbe +2 verified
    davebullockmbe Capacitance Code (pF): Two significant digits and number of zeros. Use 9 for 1.0 – 9.9 pF. Use 8 for 0.5 – .99 pF. ex. 2.2 pF = 229 ex. 0.5 pF = 508
  • davebullockmbe
    davebullockmbe over 1 year ago in reply to anniel747 +2 verified
    Interesting thanks :-)
    0 shabaz over 1 year ago
    Are these from ebay/aliexpress? Maybe it's a typo, the operator hit the 9 key instead of zero, for their printing operation (and mistakenly typed that instead of 056 too! If they have to type three digits). Could be anything if its from such a source..
  • davebullockmbe
    0 davebullockmbe over 1 year ago in reply to shabaz
    No it doesn't appear to be a 'typo' as this is the text on the actual capacitors (attached) see below. They were from a well known UK supplier although will have originated from China as does everything these days?
    I can't imagine what the 9 stands for..... it can't be a multiplier.....mysterious!
    Dave
    0 shabaz over 1 year ago in reply to davebullockmbe
    What's the brand/manufacturer part code? I'm wondering if the datasheet explains the labeling. Are these from a small hobby store reseller or a larger distributor?
  • davebullockmbe
    Well clearly it's a recognised numbering format because if you type "569 mlcc" into google the first 'hit' (AI overview) you get explains that it's a 5.6pF MLCC capacitor
    C0402C569D5GACAUTO and C0603C569C5GACTU are part numbers for 5.6 pF, 50 V multilayer ceramic capacitors (MLCCs). These capacitors are made by KEMET
    So I assume it's an established nomenclature?
    However I have never seen this before in my 50 years of industrial electronics.
    Dave
    0 michaelkellett over 1 year ago
    Have you measured them - perhaps they are 56nF Slight smile
    Not really - I just saw your bit about looking them up.
  • davebullockmbe
    0 davebullockmbe over 1 year ago in reply to michaelkellett
    Ha!
    Once the value increases above 9.1pF the familiar 100 appears to operate.
    I guess I never used MLCC's below 10pF before...amazing!
    Dave
    No, it's a manufacturer convention. Hence why the part code matters if there's any ambiguity.
    For instance, Murata MLCCs use a decimal identifier 'R' for these small values. And it's very common for older ceramic discs (i.e. not MLCC) to just directly print the value when below 10pF.
  • anniel747
    0 anniel747 over 1 year ago in reply to davebullockmbe
    davebullockmbe
  • davebullockmbe
    +1 davebullockmbe over 1 year ago in reply to anniel747
  • anniel747
    davebullockmbe Taken from the datasheet.
