Ask an Expert Forum Help identify replacement for burnt out component
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 336 subscribers
  • Views 760 views
  • e.c. cutter
  • electric scissors
  • electronics repair
See a helpful answer?
stanto
stanto 5 months ago
I have been asked to repair the charger for a family member's E.C. Cutter Electric Scissors Kit. The charger for it is supposed to output 7.5v at 1.2a and it outputs 11v and buzzes. It's completely sealed, so it's going to be replaced.
However it took the charger with it, upon opening it should a replaceable component, but I'm having trouble knowing what to look up.
Here's photos of its insides:
I'm presently in Norway, so finding parts here may be tricky and I'll have to bring it back to England to pick something up!
I'm expecting some of the diodes to have failed after checking them in diode mode on a multimeter, and the burnt out component may be a radial inductor?
  • kmikemoo
    kmikemoo 5 months ago in reply to stanto +2
    stanto You gave it a good try. If the simple fix wasn't enough... your time is more valuable on another project or endeavor. Knowing when to call "No joy" is also a skill.
  • kmikemoo
    kmikemoo 5 months ago +1 suggested
    stanto You are correct. It is an inductor. The "L1" label on the PCB helps validate that. You are also correct in that the current that caused that damage may have damaged other components. AND... it might…
  • robogary
    0 robogary 5 months ago
    The silkscreen says L1, so it is pretty likely a choke. You may have to remove L1 and put it under a magnifying glass to see if you can identify labels.
  • kmikemoo
    0 kmikemoo 5 months ago
    stanto You are correct.  It is an inductor.  The "L1" label on the PCB helps validate that.  You are also correct in that the current that caused that damage may have damaged other components.  AND... it might not have - because the rest of the PCB looks really clean.
    As to the output voltage... those little chargers have terrible regulation.  I have some that have very high unloaded output voltage levels - relative to what they are supposed to run at.  When they are connected (loaded), the voltage comes down.  If your buzzing is high pitched, you just may be hearing the power supply switching.  I have a couple of USB power supplies that I can hear - if the house is really quiet (which is rare).
    Have fun on the repair. Thumbsup
  • acdc90
    0 acdc90 5 months ago
    hello. i would start by checking the TO3 transister, L1 looks like a noise filter, if L1 measures like a short and transister does not have shorts i would power it up
  • stanto
    0 stanto 5 months ago in reply to robogary
    It is... melted, there is nothing identifiable on it.
  • stanto
    0 stanto 5 months ago in reply to kmikemoo
    I'm used to a high pitched sound, but this was like a loud, angry bee/hornet thats low pitched.
    I thought that it may be an "unloaded" issue, but the diodes seem to read values both ways and that implies damaged to me.
    I may try sacrificing another power supply to see if I can recover some parts and make something that works.
  • stanto
    0 stanto 5 months ago in reply to acdc90
    This thing is not powering up, your advice is a little confusing.
  • stanto
    I salvaged an inductor and diodes from another power supply. Unfortunately it still doesn't function.
    Its supposed to charge batteries, it lights a green led, but the secondary led when a battery is connected does not light up, and a meter on the points to the battery doesnt increase so another component has likely failed. Sadly this is one for the bin.
  • geralds
    0 geralds 5 months ago in reply to stanto
    Hi  stanto
    the most important info we need is the designator, the name of the IC. And the 2. is the big transistor - the 3pin black block, this looks like a MOSFET.
    If you know which IC you have you can rework from the PCB to the schematic, using a datasheet from them.
    I think the MOSFET as well the IC where gone.
  • kmikemoo
    0 kmikemoo 5 months ago in reply to stanto
    stanto You gave it a good try. Thumbsup  If the simple fix wasn't enough... your time is more valuable on another project or endeavor.  Knowing when to call "No joy" is also a skill. Relaxed
  • acdc90
    0 acdc90 5 months ago in reply to stanto
    What is the numbers on the TO3 transister or FET,
    were the diodes that you pulled out faulty
