Ask an Expert Forum Help identify replacement for burnt out component
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 336 subscribers
  • Views 762 views
  • e.c. cutter
  • electric scissors
  • electronics repair
See a helpful answer?
stanto
stanto 5 months ago
I have been asked to repair the charger for a family member's E.C. Cutter Electric Scissors Kit. The charger for it is supposed to output 7.5v at 1.2a and it outputs 11v and buzzes. It's completely sealed, so it's going to be replaced.
However it took the charger with it, upon opening it should a replaceable component, but I'm having trouble knowing what to look up.
Here's photos of its insides:
I'm presently in Norway, so finding parts here may be tricky and I'll have to bring it back to England to pick something up!
I'm expecting some of the diodes to have failed after checking them in diode mode on a multimeter, and the burnt out component may be a radial inductor?
  • kmikemoo
    kmikemoo 5 months ago in reply to stanto +2
    stanto You gave it a good try. If the simple fix wasn't enough... your time is more valuable on another project or endeavor. Knowing when to call "No joy" is also a skill.
  • kmikemoo
    kmikemoo 5 months ago +1 suggested
    stanto You are correct. It is an inductor. The "L1" label on the PCB helps validate that. You are also correct in that the current that caused that damage may have damaged other components. AND... it might…
  • robogary
    0 robogary 5 months ago in reply to stanto
    Sometimes a hard business decision has to be made. Now you have more time to sit in the sunshine with your favorite lemonade. :-) Grinning
  • stanto
    0 stanto 5 months ago in reply to geralds
    Unfortunately I was not in a position to replace those parts within the time and resources available, surprisingly getting hold of parts like this in Norway is not trivial.
