Ask an Expert Forum Can anyone assist with diagram of connections for anchor rod control system based on Hall effect?
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 335 subscribers
  • Views 870 views
See a helpful answer?
Irek
Irek 4 months ago
It should count numer of revolutions (not rpm) of the gybsy wheel of the anchor winch./ik
Diagram that I have drawn can be sent to interested party./ik
    shabaz 4 months ago +1
    The Interested party you refer to might ultimately not have the answer, wasting their time as well as yours. It's more productive to just post it online for all to see.
  • beacon_dave
    beacon_dave 4 months ago in reply to Irek +1
    Diagram has been uploaded to another forum post: https://community.element14.com/technologies/experts/f/forum/57057/use-of-hall-effect-sensor-for-revolutions-counter-not-tacho
  • beacon_dave
    beacon_dave 4 months ago in reply to shabaz +1
    It's in a new forum post here: https://community.element14.com/technologies/experts/f/forum/57057/use-of-hall-effect-sensor-for-revolutions-counter-not-tacho
  • Irek
    0 Irek 4 months ago in reply to beacon_dave
    Thx Dave for condirming./ik
  • acdc90
    0 acdc90 4 months ago in reply to Irek
    what sensor device are you using,  ?
    your diagram shows sensor is supplied from 12v  what does sensor need ?
    could you have damaged it if it should only have 5v supply
    then some sensors will all so need a pull up resister for out put     ?
    0 shabaz 4 months ago
    From a brief examination the setup looks reasonable, and there's decent confidence if you say you tested beforehand and it worked.
    Your actual deployment may be vastly different in unexpected ways, but it's not apparent from the notes. For example, the power source may be different, or cable lengths may be significantly different than the test setup.
    You need to do some basic voltmeter checks to confirm the correct voltages are present on the correct expected locations, maybe even do a continuity check with power disconnected, because connectors may have issues. Check if the sensor is inductive or magnetic sensitive, and is it being permanently stuck high or low due to other metal nearby. At slow revolutions you could probably test with an LED and resistor, temporarily detatching the sensor output wire from the counter, and wiring to the LED instead.
    Similarly, you could check the counter and wiring in isolation by temporarily disconnecting the sensor and applying a pulse manually.
    Best to buy a couple of sets of components so you can have a permanent testbed set up to compare against, since the parts are quite low cost.
  • beacon_dave
    0 beacon_dave 4 months ago in reply to shabaz
    If it is hall effect, then perhaps also check the polarity of the magnet.
  • Irek
    0 Irek 4 months ago in reply to shabaz
    Thx Shabaz for good pointers.  When trouble shooting I took all my set up apart and use small 12vdc battery and rigged up just sensor and display directly to eliminate connections/cabling continuity issues and tried to move the sensor ver the magnet.  No results.  Some people suggest that load should be included in the sensor circuits.  Did not try this yet as I have no idea what resistor is required.  Good idea with the LED.  This should tell me if counter is faulty or sensor.  Will try it.
    Anyhow thx for yr advise , it gave me some ideas for triouble shooting./ik
  • beacon_dave
    0 beacon_dave 4 months ago in reply to Irek
    The documentation you have on the counter looks like it includes an example circuit for counting with NPN type sensors. You have only included the switch example in your PDF though.
