Ask an Expert Forum remote control system
  • Replies 7 replies
  • Subscribers 303 subscribers
  • Views 966 views
  • frontpage
See a helpful answer?
yinny1
yinny1 over 8 years ago
hi there i was wanting help here i am doing a remote control system for a project that will consist of
transmitter (has 12 channels and i can select up to 150 districts lcd to say witch district is selected)
receiver (aka district that has 12 outputs (to preferably control relays)
access card (a pcb card that will have a microcontroller on (3 needed to turn on the receiver (each one with there own code)
what i would like
easy expatiation
minimal cable run
what i think can be useful
rs232 (for communications from the transmitter to the receivers)
apart from that i have not got much els at the moment
  • rachaelp
    rachaelp over 8 years ago +1
    Hi Sam, You've already posted this in another section of the forum. Posting the same thing multiple times won't get you any more responses and it'll just get confusing with people thinking their replies…
  • jfst
    jfst over 8 years ago +1
    further replies here: remote control system
    DAB over 8 years ago
    Hi Sam,
    You need to provide us with more information on the project.
    What is the purpose of the device, ranges, communication speeds, data size, data volume, command timing, power issues, plus all the other detail you can provide.
    How about a block diagram showing the components and how you envision their connections.
  • rachaelp
    Hi Sam,
    You've already posted this in another section of the forum. Posting the same thing multiple times won't get you any more responses and it'll just get confusing with people thinking their replies have gone missing if they look at the same query in another place. Please can you refrain from making the same post multiple times in future.
    Rachael
  • jfst
  • yinny1
    yinny1 over 8 years ago in reply to DAB
    the max range i will be going is about 150m i dont quite know what communication speed data size or data volume or comand timeing each unit wil have its own power supply
    it dose not have to be rs232 i just thought it could be the best
    how i see it is basically a set of momentary switches to control relays but i can have bans of relays and as little wier as possible the lcd to show witch district is selected
    and the access cards are basically a unique glorified switch basically each card has its own unique code/key and when all 3 are connected it can energise a relay to activate the system
  • yinny1
    yinny1 over 8 years ago in reply to rachaelp
    i know sorry i forgot and when i posedit here i just remembered i posted it some were els
    DAB over 8 years ago in reply to yinny1
    I always get concerned when you select equipment before you define and design the system.
    It is better to take some time to consider your options, look at usage issues and assess the need for growth.
    Your current approach may work, but you will probably find the need to make some major changes when you find the initial build too limited for effective use.
    A little up front time can save you a lot of headaches in the long run.  Trust me, I know.
  • yinny1
    i have a desing in minde and how it will all go together and this is a first run to see if i whant to make any changes/improvements
