Internet of Things
Internet of Things
Blog Azure Sphere (MT3620)
  • Author Author: bwilless
  • Date Created: 19 Nov 2018 3:27 PM Date Created
  • Views 2438 views
  • Likes 12 likes
  • Comments 8 comments
  • azure sphere
  • avnet
  • mt3620
  • iot
bwilless
bwilless
19 Nov 2018
My name is Brian Willess, I work at Avnet where I'm responsible for training Azure Sphere customers.  I wanted to advertise the MT3620 Azure Sphere device and its supporting systems to this community.  Azure Sphere has everything you need to develop and deploy a secure IoT solution quickly.
Azure Sphere
The Azure Sphere system developed by Microsoft combines a secure MCU, secure OS (Linux kernel), and the Azure Sphere Security Service (in the cloud) to deliver a highly secure IoT solution.  Just a few of the key benefits of the system are listed below:
  • Certificate based authentication to the cloud (Managed by Microsoft)
  • Threat monitoring (Managed by Microsoft)
  • Over the air updates (Managed by Microsoft)
    • OS updates included for 13 years
    • OEM application updates included for the agreed life of your device
  • Sphere development is integrated into the Visual Studio development environment
    • Secure connections to Azure works out of the box
    • Support for telemetry data, device twins, remote method calls are all included with the Sphere SDK
    • Remote GDB real-time debugging using Visual Studio debugger interface
7-Properties of a highly secure device
One of the fundamental design goals in the Azure Sphere ecosystem is security.  Microsoft has some experience with security; the first two generations of the XBox were both hacked within weeks of release.  Microsoft decided to do something about that and spun up a research team to solve the problem.  This team developed the 7 Properties of a Highly Secure device, white paper here.  The latest XBox system implemented the 7-Properties and has not been hacked.  (Note that the XBox does NOT use the Azure Sphere device).  These 7-Properties are all implemented in the Azure Sphere solution.
  • Hardware Root of Trust – The identifying cryptographic keys are embedded and protected by secure element physical hardware with a hardware firewall around it.
  • Certificate-Based Authentication – Well beyond passwords, certificates are unforgeable and prove device authenticity.
  • Small Trusted Computing Base – Only a small portion of the device firmware has access to the private cryptography keys.
  • Defense in Depth – Multiple layers of security that mitigate attacks.
  • Compartmentalization –  On-Chip Software Systems are highly compartmentalized, leaving little access from compartment to compartment.
  • Failure Reporting – Ecosystem monitoring to watch for threats, and threat methodologies.
  • Renewable Security – Let Microsoft update security systems – Just like a Windows System update.  Nice.
Azure Sphere Links
  • Azure Sphere Documentation
  • Azure Sphere Overview (Video)
Brian
  • Workshopshed
    Workshopshed over 8 years ago +3
    Hi bwilless the Azure Sphere is something I'm working with at the moment, you can follow along with my project on the blog. https://www.element14.com/community/people/Workshopshed/blog/tags#/?tags=azure…
  • Fred27
    Fred27 over 8 years ago +1
    Azure Sphere sounds interesting but the documentation and ecosystem seem a bit lacking right now. For instance, the examples available at the moment seem to just deploy code to one of the M4F cores. Is…
    shabaz over 8 years ago +1
    Interesting device : ) Nice that it is all very integrated into a single package at 12x12mm.. impressive!
  • highpocket
    highpocket over 7 years ago
    This thing is an absolute nightmare to setup. I keep getting a tenant error and wont connect to an account.
  • highpocket
