Internet of Things
Internet of Things
Blog Bumpy Road? : Connecting an Arduino MKR1310 WAN to The Things Network
  • Date Created: 28 Aug 2020 5:16 PM Date Created
  • Views 3403 views
  • Comments 8 comments
  • mkr_1310_wan
  • ttn
  • the_things_network
  • iot
28 Aug 2020
Here's my first experience with the Arduino MKR1310 and The Things Network (TTN).
A (failed) attempt to follow the tutorial and connect to TTN.
I'm using a Arduino MKR 1310 WAN, tested with two different 868 MHz antennas, in an area known to be covered by TTN.
I'm following the tutorial step by step.
  • installed the latest board support: Arduino SAM Boards version 1.8.7
  • and latest MKRWAN lib, 1.0.12
Made an application on TTN:
Loaded the FirstConfiguration sketch to my board:
Ran it:
Registered my device using the Device EUI:
Selected OTAA, and entered the APP EUI and KEY.
No success. The board returns "Something went wrong; are you indoor? Move near a window and retry", and TTN console says there was no contact.
image source: the things network
image source: ttn mapper. I live uphill, one of the highest parts of the city called "Litlle Hill". In a beam.
Any advice?
  • fmilburn
    fmilburn over 6 years ago +2
    I was never able to make a TTN connection when I lived in Seattle. I have two MKR1310s and they communicate OK between each other. Possible causes for my problems: TTN stations were sparse in my area and…
  • ralphjy
    ralphjy over 6 years ago +1
    I have 2 MKR1300s and a TTN gateway. Don't know if the newer boards improved range. I'm not sure what kind of coverage you are expecting but the nearest gateway on your map looks to be about 3km away.…
  • fmilburn
    fmilburn over 6 years ago in reply to fmilburn +1
    Correction: mine are MKR1300, not 1310. I looked back at my notes and the furthest successful transmissions with my antennas was under a kilometer and that was unobstructed line of sight.
  • ralphjy
    I have 2 MKR1300s and a TTN gateway.  Don't know if the newer boards improved range.  I'm not sure what kind of coverage you are expecting but the nearest gateway on your map looks to be about 3km away.  I live in an medium density suburban neighborhood and I could never get even close to that range.  Of course, I don't have my gateway antenna outside but I doubt that I can do a kilometer.  I think as Frank says, if you have a direct line of sight and no frequency interference you can probably do better.  I don't typically use my units outside the perimeter of my yard.  Maybe you could try getting nearer to the Central Station.
  • ralphjy
