Internet of Things
Internet of Things
Blog Problems talking to CC3200 Launchpad with Energia
  • Date Created: 30 Oct 2014 6:35 PM Date Created
  • Views 2965 views
  • Comments 16 comments
  • cc3200_launchpad
e14 Contributor
e14 Contributor
30 Oct 2014
I've spent several hours trying to communicate with the above controller using Energia but without success. I'm really hoping someone will take pity on me and offer some ideas!
The problem I think is with the drivers, or lack of them. I downloaded the driver zip as recommended by Github (EZ430-UART.zip) and unzipped them. If I plug the CC3200 into the USB port Windows tries to install the drivers but when I direct the driver installation wizard to the unzipped files it seems to think they are not relevant and so fails. If I open Device Manager then the CC3200 is showing up as USB<->JTAG/SWD but with a query over it as there are no installed drivers. I wonder if that is telling me something, I would have thought I really needed a COM link not a JTAG link (?). I've tried this on a 32 bit machine and a 64 bit machine - same results.
I have a project waiting to go online using WiFi and this is really frustrating. I get the feeling it's something quite simple but I can't seem to see it. I've checked all the PCB links against the TI User Guide and can't see any problem.
  • BigG
    BigG over 11 years ago
    I take it you have read the information provided in Guide_CC3200LaunchPad | Energia
    and http://energia.nu/cc3200guide/
    within the cc3200 guide there is another link to the windows setup process Guide_Windows | Energia
    On this page look at listed item 2 where there is a link which when clicked will download a zip file with the required drivers.... I don't know much about the Github option (that may be for the 430 controller anyway, so may not be relevant)
    Need to do that before connecting anything.
    ... I now see your uploaded images. Maybe refer to the FTDI section for an explanation on the "ACK failed" message.... just added link to make it easier FTDI Knowledgebase
    ... and I take it you have the jumper placed in correct position to allow for programs to be uploaded via Energia: http://energia.nu/wordpress/wp-content/uploads/2014/09/jumper.png
    To upload any updated firmware onto the cc3200, all you need is the Uniflash program, which is a utility that will upload files onto the cc3200 for you.
    You do not need to CCStudio for any of this.... otherwise you spend a couple of hours downloading and configuring that which can be done later as Energia should suffice to get you going.
    Hope that helps.
  • BigG
    Hope that helps.
