Internet of Things
Internet of Things
Blog Reverse Engineer NFC Card Reader Protocol of Digital Logic µFR - part 0: intent
  • Date Created: 27 Mar 2020 11:26 AM Date Created
  • Views 1419 views
  • rt
  • nfc
  • java
27 Mar 2020
Digital Logic have a very nice set of Smart Card readers. I have purchased one of those.
They work well with the Infineon Securyty 2Go smart cards I received for the Infineon Blockchain Starter Kit road test.
Its a well buit reader from a interesting company. But there's a but image.
The readers don't support PC/SC, and to program them, you depend on libraries and executables that are available in binary format.
edit 15-dec-2020: there's a Windows PcSc driver available now for the µFR.
Many, but not all, utilities come with source code. They have dependencies on D-Logic libs that are released in binary only though.
Others utilities are available as executables, but the Linux binaries are for Intel platforms. No Arm, so not runnable on a Raspberry Pi or BeagleBone. And that's where I need them.
I'd like to avoid libs with unknown license in a public blog. And I'd like to find an open way to talk to the NFC device.
There may be a solution. D-Logic published an Android Java example that's not dependent on their proprietary libraries.
This example / user tutorial is not depending on D-Logic libraries.
It is depending on FTDI's serial lib - but that's in essence a serial communication wrapper. By just reading how the lib is called in the example you can defer what's requested on the serial side.
All other dependencies are open source or standard (android, java.io, java.util and xmlpull.org).
import android.app.PendingIntent;
import android.content.BroadcastReceiver;
import android.content.Context;
import android.content.Intent;
import android.content.IntentFilter;
import android.content.pm.PackageManager;
import android.hardware.usb.UsbAccessory;
import android.hardware.usb.UsbManager;
import android.os.BatteryManager;
import android.os.Build;
import android.os.ParcelFileDescriptor;
import com.ftdi.j2xx.D2xxManager;
import com.ftdi.j2xx.FT_Device;
import org.xmlpull.v1.XmlPullParser;
import org.xmlpull.v1.XmlPullParserException;
import java.io.FileDescriptor;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.util.ArrayList;
This should be doable. My next steps will be to try and find the flow in the example.
Then find where the essentials for APDU communication.
Then abstract away dependencies on android and FTDI. Hang on ...
Related Blog
Blockchain - Talk Directly to the Infineon 2Go Smart Cards API
µFR NFC Card Reader - part 1: first C program for Linux (RPi, BB, ...)
µFR NFC Card Reader - part 2: first C++ program
µFR NFC Card Reader - part 3: C++ Class to handle ISO14443 / APDU cards
µFR NFC Card Reader - part 4: first meaningful ISO14443 / APDU conversation
µFR NFC Card Reader - part 5: refactor, look back at initial design
    Jan Cumps over 5 years ago in reply to Jan Cumps +2
    First successful C program talking to a smartcard:
    Jan Cumps over 5 years ago +1
    For my own investigations: Here's what I get when plugging it in a Linux USB port (Debian Stretch) dmesg output: [ 1095.171507] usb 1-1.3: new full-speed USB device number 6 using dwc_otg [ 1095.328978…
    dmesg output:
    [ 1095.328978] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001
    [ 1095.328992] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 1095.329001] usb 1-1.3: Product: uFR Nano Plus
    [ 1095.329010] usb 1-1.3: Manufacturer: D-Logic
    [ 1095.329017] usb 1-1.3: SerialNumber: A659Z65G
    [ 1095.374106] usbcore: registered new interface driver usbserial
    [ 1095.374175] usbcore: registered new interface driver usbserial_generic
    [ 1095.374230] usbserial: USB Serial support registered for generic
    [ 1095.386858] usbcore: registered new interface driver ftdi_sio
    [ 1095.386938] usbserial: USB Serial support registered for FTDI USB Serial Device
    [ 1095.387356] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
    [ 1095.387493] usb 1-1.3: Detected FT232RL
    [ 1095.388435] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
    lsusb output:
    Bus 001 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
    A few health checks Digital Logic lists, that can influence the operation:
    I may have to deal with FTDI auto-loading modules. :
    lsmod | grep ftd
    ftdi_sio               40960  0
    usbserial              40960  1 ftdi_sio
    I'll first check if I have issues. If yes, I have to blacklist the drivers.
    There's also a PC/SC driver in development. That would be great news. It would make the reader plug-compatible with several BitChain libraries.
    dmesg output:
    lsusb output:
    lsmod | grep ftd
    ftdi_sio               40960  0
