Internet of Things
Internet of Things
Blog Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 2: full install and run as service
  • Date Created: 29 Dec 2023 8:24 PM Date Created
  • Views 7525 views
  • Comments 18 comments
  • raspberry
  • the things network
  • lorawan
  • ttn
  • gateway
  • iot
29 Dec 2023
In part 1,  Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 1: build and test , I compiled the software for the Elecrow LoRaWAN gateway (see  Low-Cost LoRaWAN Gateways! ), and enabled the gateway on The Things Network (TTN). I used Raspberry OS bullseye 32-bit lite on a Raspberry Pi  A+. I tested this on a B+ with the same OS too.
In part 2, the software gets properly installed, and I configure it as a systemd service.
Install the software.
I'm going to install it in a bin folder of the user that will run the service (jancumps).
Instructions are on GitHub: SX1302 LoRa Gateway project - 4.2. Install executables and associated files in one directory:
mkdir ~/sx1302_hal
mkdir ~/sx1302_hal/bin
Then navigate to the build folder from post 1 and edit the install config file
cd LR1302_loraWAN
cd LR1302_HAL
cd sx1302_hal
nano target.cfg
Check that the right folder and user are configured. Don't use the relative user path, but the full one.
Then it's time for installing the software in the bin folder we just created. It's worth investigating how to set up ssh certificate logon for localhost, or you'll have to type your password a lot of times. See the link at the start of this section for instructions.
Then install the binaries and config:
make install
make install_conf
Different than the instructions:
cd ~/sx1302_hal/bin
chmod +x reset_lgw.sh
The application is now installed.
Test:
./lora_pkt_fwd -c global_conf.json.sx1250.EU868
success:
Install and run as a daemon
The instructions are also on Github: How to auto-start the with systemd.
In your build directory, there is a script file:
cd ~/LR1302_loraWAN/LR1302_HAL/sx1302_hal/tools/systemd
nano lora_pkt_fwd.service
Adapt to the directory structure and user for your install. If you followed my instructions, you should only check the home folder.
I also tell systemd what group and user name to run this particular service under:
User=jancumps
Group=jancumps
Then copy the service file, register it, and enable:
sudo cp lora_pkt_fwd.service /etc/systemd/system
sudo systemctl daemon-reload
Before starting the service, let's redirect the output, so we can monitor it
sudo cp lora_pkt_fwd.conf /etc/rsyslog.d
sudo systemctl restart rsyslog
Start a second console to the Pi, to view the log (a new PuTTY session, or whatever Terminal program you use):
journalctl -u lora_pkt_fwd -f
Let it sit there. Any message from the service will show up there.
In the original terminal, enable and start the service;
sudo systemctl enable lora_pkt_fwd.service
sudo systemctl start lora_pkt_fwd.service
You can safely close all consoles now. Things will keep on running. Even after reboot. Executing this command at any time will show the log:
And this will show the service status:
systemctl status lora_pkt_fwd.service
Enjoy
In theory, you don't need the build directory structure anymore ...
See also: Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 3: manage the service log size
    Jan Cumps over 2 years ago
    (from previous comment:) TTN's fair use budget for a thing - in the free tier - is 30 seconds of uplink airtime per day.
    What time does an initial connection with data exchange take? "consumed_airtime": "1.318912s",
    Activity:
    Accept join-request
    Successfully processed join-request
    Forward join-accept message
    Forward uplink data message
    What time does typical data exchange take?  "consumed_airtime": "0.061696s",
    activity:
    Forward uplink data message.
    This data is not coming from my gateway. It's on the TTN application log of my TTN account.
    Resource use on a Pi A+:
    service log file handling on the Pi:  Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 3: manage the service log size
    Jan Cumps over 2 years ago in reply to Jan Cumps
    correction: fair use is 30 seconds per day.
    I have set up an Arduino MKR1310 as "pinger". It will send one metric every 2 hours.
    TTN "sandbox fair use" asks to have no more than 12 seconds of uplink communication per 24 hours. Having 12 communications per day should keep me under that threshold.
    Arduino Code:
    #include "arduino_secrets.h"
      Sketch generated by the Arduino IoT Cloud Thing ***
      https://create.arduino.cc/cloud/things/*****
      Arduino IoT Cloud Variables description
      The following variables are automatically generated and updated when changes are made to the Thing
      int health;
      Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
      which are called when their values are changed from the Dashboard.
      These functions are generated with the Thing and added at the end of this sketch.
    #include "thingProperties.h"
    void setup() {
      // Initialize serial and wait for port to open:
      Serial.begin(9600);
      // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
      delay(5000);
      // Defined in thingProperties.h
      initProperties();
      Serial.println(APPEUI);
      Serial.println(APPKEY);
      ArduinoCloud.enableRetry(true);
      ArduinoCloud.setMaxRetry(5);
      ArduinoCloud.setIntervalRetry(10000);
        // Connect to Arduino IoT Cloud
      ArduinoCloud.begin(ArduinoIoTPreferredConnection);
         The following function allows you to obtain more information
         related to the state of network and IoT Cloud connection and errors
         the higher number the more granular information you’ll get.
         The default is 0 (only errors).
         Maximum is 4
      setDebugMessageLevel(2);
      ArduinoCloud.printDebugInfo();
      pinMode(LED_BUILTIN, OUTPUT);
      digitalWrite(LED_BUILTIN, ArduinoCloud.connected());
    void loop() {
      static int loopcounter = 0;
      ArduinoCloud.update();
      // Your code here
      if (loopcounter % (6 * 60 * 2) == 0) { // every 2 hours
        loopcounter = 0;
        health = health + 1;
      delay(10000);
      loopcounter ++;
      Since Health is READ_WRITE variable, onHealthChange() is
      executed every time a new value is received from IoT Cloud.
    void onHealthChange()  {
      // Add your code here to act upon Health change
    Log on the gateway:
    Jan 5 11:17:09 raspberryttn lora_pkt_fwd[788]: INFO: Received pkt from mote: 2700AE9E (fcnt=0)
    Jan 5 13:16:10 raspberryttn lora_pkt_fwd[788]: INFO: Received pkt from mote: 2700AE9E (fcnt=1)
