Internet of Things
Internet of Things
Blog Suggestion needed for a IoT solution
  • Date Created: 29 Jun 2015 8:41 AM Date Created
  • Views 1601 views
  • sensors
  • internet_of_things
  • iot
e14 Contributor
e14 Contributor
29 Jun 2015
Hello i am developing a IoT product.
basically there are lot of nodes separated by 100-200metre apart. they are battery operated by 2100mah AA alkaline battery. and i want the life to be 6-8 month on each charge cycle.
The sensor node consumes 30-50ma for getting data from the sensors, and i need to tx it for 1sec every one hour, and i need a mesh kind of network,.
It seems sub GHZ will help in this scenario, still confused on which chip i should go./
Found several chips from Ti,SiLabs,Freescale,Atmel.
Anyone suggest me a best chip-set for my application. footprint doesn't matter.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    I have used the TI Sub 1GHz and they work very well and are reliable and well supported, you can et a pair from TI / Newark for about 20$ as Booster packs, they come with an MSP430 CPU each as well so…
    dougw over 11 years ago
    A lot of nodes in a mesh network sounds like a good application for a Zigbee network - if your nodes have the horsepower to run a Zigbee stack.
