Internet of Things
Internet of Things
Forum Need help building a module using PAN1721
  • Subscribers 521 subscribers
  • Views 535 views
  • pan1721
I am new to hardware design and need to build a module using the Panasonic PAN1721 that I connect some sort of temperature sensor to and power. Is this an easy task ? Where to start ? Does anything similar that can be bought exist ?
Thanks.
    shabaz over 10 years ago
    Hi Kamal,
    I can't say if it is easy or not, depends on how comfortable you are developing software.
    Anyway, there is a page that describes what software stacks are available here: Introducing the PAN1721, a complete power optimized Bluetooth v4.0 Low Energy (BLE) solution
    Also, the TI page for the CC2541 (which I believe is what the PAN1721 uses) will help you too, you'll find the datasheet, tools and software there for TI's stack.
    e14 Contributor over 10 years ago in reply to shabaz
    Thank you for that.
    I am familiar with the PAN1721 chip and the CC2541 it uses. My issue is building the hardware i.e. building the circuit to connect the chip with power supply and a sensor.
    Thanks.
