Internet of Things
Internet of Things
Forum Super simple wireless current sensor - need pointers getting started
  • Subscribers 523 subscribers
  • Views 656 views
I haven't done hobby electronics in many years, but am looking to get started with a small project I've had in my mind for a while.
I want to build a super simple wireless current sensor for a 120V outlet, sort of like a wireless kill-a-watt, (see http://www.amazon.com/P3-P4250-Kill-Watt-Wireless/dp/B00I9P2B8C/ref=sr_1_1?ie=UTF8&qid=1457804948&sr=8-1&keywords=wirele…)
I need to be able to read the 120VAC current draw from multiple appliances transmitted wirelessly to a central received hooked to a Raspberry Pi.
There are 4 parts to the wireless sensor
1. Power converter - 120VAC to 5VDC to power the circuit
2. 120V current sensor
3.  some micro controller to read output from part 2 above and drive wireless transmitter
4. wireless transmitter (Bluetooth LE or 433 Mhz)
I've googled and found chips for all parts, but want to avoid reinventing the wheel if someone's done something like this before
-What's the minimum ICs that can do all the above?
-What the cheapest way to do this assuming it will be running all the time and the data will be transmitted continuously at 1 sec intervals?
Thanks for any pointers!
  • peterjcs23
    peterjcs23 over 10 years ago +1
    there are probably 127 ways of doing your project and they will all work just fine. You can narrow the range of choice be defining the range of the wireless and the gateway you are transmitting to and…
  • clem57
    clem57 over 10 years ago
    Is the CO2 part not needed?
    Clem
  • musskopf
    musskopf over 10 years ago
    I have just started a project for a development board based on Avr Atmega328p (same as Arduino), with built-in wireless and capable of running on batteries for long periods. I believe a pair of those boards can easily solve itens 3 and 4. Regarding the item 1, as I said you'll be able to run in on batteries,  otherwise a simple Usb charger can be used.
    Now for the current sensing, there are many option, check for those clip inductive current sensing (https://www.sparkfun.com/products/11005), they are contactless and pretty safe. You should be able to use the analog port on the MCU for that.
    Check out my project here: https://www.kickstarter.com/projects/340271897/whisper-node
    Cheers,
    Mike M.
  • peterjcs23
    there are probably 127 ways of doing your project and they will all work just fine. You can narrow the range of choice be defining the range of the wireless and the gateway you are transmitting to and then choose a microcontroller that has the RF built in.
