Internet of Things
Internet of Things
Forum Where do you store/hide your AES keys used for embedded encypt and decrypt?
  • Replies 36 replies
  • Answers 8 answers
  • Subscribers 523 subscribers
  • Views 16029 views
  • aes
  • aes_encryption
  • keystore
  • iot
  • aes_decryption
Jan Cumps
Jan Cumps over 10 years ago
In a scenario where you have two embedded systems talking to each other,
and you want to encrypt/decrypt the data with AES,
where/how do you store the AES key in your firmware sources?
If I put my aes-128-ecb in my source code of my firmware like this:
    /* Set up the variables */
    uint8_t aesKey[16] = {
            0x5a, 0x69, 0x67, 0x42, 0x65, 0x65, 0x41, 0x6c,
            0x6c, 0x69, 0x61, 0x6e, 0x63, 0x65, 0x30, 0x39
it's  out there for everyone that has access to the version control system, and can leak to the outside world.
What's your approach?
  • brianonn
    brianonn over 10 years ago +5 suggested
    Definitely don't check any encryption keys into source control. Let's look at the problem: While programming your APIs you see that you needed an AES key for encrypting your shared link. The problem you…
  • clem57
    clem57 over 10 years ago +2
    I would take the AES 256 bit key and encrypt with a private-public key pair RSA 1024 bit. Public is safe out in the open, but the private is stored on a USB medium on a system with a locked keyring. This…
  • Fred27
    Fred27 over 10 years ago +2 suggested
    Would a "good enough" solution be to have this in a separate file that's ignored by source control? It would in theory be accessible by anyone who could get hold of the firmware, but that would be hard…
    0 Jan Cumps over 10 years ago
    Yet another option:
    tamper-proof physical key storage device:
    0 shabaz over 10 years ago in reply to Jan Cumps
    Hehe in some ways these techniques can be even more effective than the security chips, since these can (when they work) wipe off the certs/keys. I'm pretty sure it does more than just temporarily removing the power from the SRAM though - probably does that followed by actively programming new data into the memory. Anyway even if someone succeeds in breaking through all this, they really can only compromise that one device, not all of them. That's the beauty of public key encryption.
    Of course, there is a cost involved to all of this. But, if the loss will be significant then it would be worth it.
    If every IoT device has to have companion hardware, that is complex & expensive.  PKI is the best compromise in 2016 - AES protected data at a reasonable cost with no symmetric keys handled or exposed.
    That was the motivation for my DIY CA project on RPi.  Corporations can afford to splurge on a well-known CA Like Thawte.
  • BigG
    0 BigG over 10 years ago
    would something like this provide a workable solution ATECC508A
  • crjeder
    0 crjeder over 10 years ago in reply to BigG
    Yes, It would.
  • kas.lewis
    0 kas.lewis over 10 years ago
    Thought this may be of interest here.
    Kas
    imageFuture Electronics - NXP Secure Access Lab Guide.pdf
    imageFuture Electronics - Designing with Security in Mind FTF-INS-N2039.pdf
