Internet of Things
Internet of Things
Forum Conecting 3 devices wirelessly
  • Subscribers 521 subscribers
  • Views 1143 views
nicoloquinte
nicoloquinte over 9 years ago
Hello ,I' m currently making a project and I need to connnect two controllers to a master device and I want it to have only one emmiter/reciever (max 70-80M range or a bit less)
What technology I would use ?
  • BigG
    0 BigG over 9 years ago
    A few questions to narrow it down a bit.
    Will the controllers be indoors or outdoors?
    How often will the controllers need to communicate with each other. i.e. continuous streaming or intermittent?
    Then how much data will be sent per transmission.
  • nicoloquinte
    0 nicoloquinte over 9 years ago in reply to BigG
    Thanks for answering me,
    The thing will be outdoor and the controllers don't need to communicate to each other the connection need to be continuous streaming but the two controllers need to send continuous data to the receiver, the data will be a combination of different text strings in the form of packets (could be full serial text / non-encrypted.)
    moreover, the object can fly at 15 Km/h.
    Nico
  • BigG
    0 BigG over 9 years ago in reply to nicoloquinte
    If it is just text characters then my suggestion would be to look at using ANT radio transceiver module or new Bluetooth 5 transceiver module.
    0 dougw over 9 years ago
    ZigBee, Bluetooth, and Wi-Fi can also go 100m. I would likely try Bluetooth for simplicity at all nodes.
  • nicoloquinte
    0 nicoloquinte over 9 years ago in reply to dougw
    Ok thanks for all I will use bluetooth (I didnt knew the range could be so enormous)
