Internet of Things
Internet of Things
Forum Starting an IOT Lab at my coworking space
  • Answers 3 answers
  • Subscribers 522 subscribers
  • Views 1440 views
hoongkor
hoongkor over 9 years ago
I need to learn how to start an IOT Lab at my premise. What are he basic requirement/prerequisites for an IOT lab. The premise is equipped with high speed internet service. The area i have allocated for the lab is about 80 to 90 square meters. Some advice on the estimated cost of equipment and tools would be appreciated.
  • fvan
    fvan over 9 years ago +5 suggested
    Can you define your interpretation of "IoT Lab", as this is simply too vague? Are you building the lab for yourself or for someone else? What are the lab owner's requirements?
    dougw over 9 years ago +4 suggested
    The minimum is workbenches with electrical power outlets, ethernet connection and Wi-Fi. After that the sky is the limit, just like any lab. You can have hand tools, test leads, jumpers, cables, wire power…
    balearicdynamics over 9 years ago in reply to dougw +1 suggested
    Doug, you have depicted almost everything. To this list of essentials you have missed Breadboars and breadboarding wires and prototyping 2.5 mm holes PCBs. And a couple of micro controllers e.g. Arduino…
  • fvan
    0 fvan over 9 years ago
    • Vote Up +5 Vote Down
  • hoongkor
    0 hoongkor over 9 years ago in reply to fvan
    I am a founder of a new coworking space. As an additional facility for the members I plan to set up a IOT Lab for those are are interested to explore the new technology and learn more of its application.
    0 dougw over 9 years ago
    You can have
    • hand tools, test leads, jumpers, cables, wire
    • power tools
    • test equipment - power supplies, oscilloscopes, DVMs, function generators, breadboards, etc.
    • office equipment - printers, copiers, computers, webcams, CAD software, simulation software, phones, tablets
    • assembly equipment - soldering stations, hot air guns, microscopes,
    • building equipment - drill press, 3D printers, sheet metal machines, CNC mill, lathe, laser cutters, etc
    • programming adapters - jtag, ftdi, etc.
    • material stock - plastic, wood, sheet metal, screws, nuts & bolts, fasteners, etc.
    • components - connectors, resistors, capacitors, inductors, LEDs, op-amps, relays, switches, etc.
    • MCUs
    • modules
    • radio modules - Bluetooth, BLE, Wi-Fi, Zigbee, LoRa, ANT, SimpleLink, GPS, etc.
    • sensors
    • chips
    I  would start with power supplies, a drill press, a DVM and a PC.
    0 balearicdynamics over 9 years ago in reply to dougw
    Doug, you have depicted almost everything. To this list of essentials you have missed Breadboars and breadboarding wires and prototyping 2.5 mm holes PCBs. And a couple of micro controllers e.g. Arduino and Raspberry Pi (beaglebone, and others)
    Just to start with somethings.
    Enrico
