Internet of Things
Internet of Things
Forum Success connecting to Arduino Cloud / TTN with MKR WAN 13x0: share your experience (solved)
  • Replies 33 replies
  • Subscribers 517 subscribers
  • Views 13198 views
  • ttn
  • cloud services
Jan Cumps
Jan Cumps over 4 years ago
update: solved - it was the coverage.
If you have been successful with sending data to The Things Network / Arduino Cloud, using an Arduino MKR WAN 1300 or 1310, please share your experience.
skruglewicz and I have tried this. The configuration worked for both of us (Arduino Cloud, TTN, customised sketch upload), but we don't get an active sub-1 GHz connection.
If you were able to exchange data, please share where you tried this, what Arduino/antenna combination, and where you placed your gizmo. And if you want, the sketch you uploaded (remove the Arduino-generated ID from the header comments).
Thank you
    Jan Cumps over 4 years ago in reply to javagoza +5
    Success! Walking tour, and in RED where I had coverage: edit: data also arrived at the Arduino cloud, as expected:
    Jan Cumps over 4 years ago in reply to Jan Cumps +5
    touristic info: the walk was partly through the Louis Bertrandlaan. One of the prettiest lanes of the Brussels district. It's a protected view since 2020. source: https://www.bruxellesbavard.be/nl…
    Jan Cumps over 4 years ago in reply to shabaz +4
    Has your MKR board worked for any non-LoRaWAN communication, e.g. just plain LoRa? I suppose it could be a faulty MKR board. Yes they are functional. I have two MKR WAN 1310s, and they can perfectly…
    Jan Cumps over 3 years ago in reply to Jan Cumps
    touristic update: I now live on this street.
    ... and I just tried - I get access to the TTN from here. It's the same gateway I could connect to  a year ago, while walking:
    Data arrived at TTN
    Arduino IOT Cloud Thing:
    IOT Cloud Dashboard:
    Customer Action Photo:
    Jan Cumps over 2 years ago in reply to skruglewicz
    I now have my own gateway running. Based on an Elecrow design suggested by shabaz :  Low-Cost LoRaWAN Gateways!
    It doesn't appear on the coverage map (yet?), but it works.
    edit: it is actually showing up: www.thethingsnetwork.org/map
    and https://ttnmapper.org/heatmap/
