Internet of Things
Internet of Things
Forum I am not able to set driver for esp32 s3 sense board
  • Subscribers 516 subscribers
  • Views 1023 views
  • esp32 s3 sense
manojroy123
manojroy123 over 2 years ago
I am not able to set driver for esp32 s3 sense board for my project can anyone help me out.
  • embeddedguy
    embeddedguy over 2 years ago in reply to manojroy123 +1
    Hi, it has been some time I have used M.Python on esp32 but normally for that first you need to load the basic M.Python firmware and then you can upload your code. I do not care for device manager driver…
  • embeddedguy
    As you are using Windows OS, which programming environment are you using? Can you flash a sample code from for example Arduino IDE?
    Also, most ESP32 devices needs to be in boot/upload mode to flash the board using buttons on the PCB. Have you checked that?
  • manojroy123
    manojroy123 over 2 years ago in reply to embeddedguy
    I am using micro python for flashing esp32 se sense board. it is not flashing. Can you share a complete process of how to do it. And what about wrong driver that is showing on device manager. How to fix that.
  • embeddedguy
    Hi, it has been some time I have used M.Python on esp32 but normally for that first you need to load the basic M.Python firmware and then you can upload your code. I do not care for device manager driver installation as it may not be recognised for esp boards.....
    here is the complete process to upload the firmware and start coding
    docs.micropython.org/.../intro.html
