Internet of Things
Internet of Things
Forum I am getting the unknow device in device manager after installing circuit python. How to install driver for it.
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 516 subscribers
  • Views 3934 views
  • circuitpython
  • adfruit
manojroy123
manojroy123 over 2 years ago
I am getting an unknown device 'CircuitPython CDC Control' in device manager after installing circuit python as given in the image bellow. Please let me know how to install driver for that device.
  • cstanton
    cstanton over 2 years ago +4 suggested
    Hello manojroy123 It appears that you are having a lot of difficulty with Circuit Python - it's great that you're asking for help on the element14 Community, and where possible other members will chime…
  • cstanton
    cstanton over 2 years ago in reply to beacon_dave +3 suggested
    beacon_dave said: It's just a warning - so unless you have additional system policies in place, it should let you continue to install it " D river signature enforcement " is enabled by default in Windows…
  • beacon_dave
    beacon_dave over 2 years ago in reply to manojroy123 +2
    As expected as the documentation clearly tells you that the signing certificate has expired:
  • cstanton
    0 cstanton over 2 years ago
    Hello manojroy123
    It appears that you are having a lot of difficulty with Circuit Python - it's great that you're asking for help on the element14 Community, and where possible other members will chime in.
    Please consider also posting your issues with CircuitPython on the Adafruit forums as they manage and maintain Circuit Python.
    You can find their forums here: https://forums.adafruit.com/viewforum.php?f=60&sid=99da2b3e111d0fa85fc190e959e5c7b7
    You will likely get immediate/detailed support there for this problem in particular.
  • beacon_dave
    0 beacon_dave over 2 years ago
    Right click the device and select the appropriate option.
    Perhaps also read the documentation provided on the Adafruit site regarding CircuitPython driver support and troubleshooting.
  • aswinvenu
    0 aswinvenu over 2 years ago
    Did you try installing the drivers from https://learn.adafruit.com/welcome-to-circuitpython/windows-7-and-8-1-drivers ?
  • manojroy123
    0 manojroy123 over 2 years ago in reply to aswinvenu
    yes, this is the error I am getting during installation.
  • manojroy123
    Tried other way around for installing driver, this is the error I am getting.
    • Vote Up -1 Vote Down
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to manojroy123
  • manojroy123
    0 manojroy123 over 2 years ago in reply to beacon_dave
    Ok,thanks.
  • manojroy123
    How to install this unsigned driver. As I have never install unsigned driver before. Can you help me out in it.
  • beacon_dave
    It's just a warning -  so unless you have additional system policies in place, it should let you continue to install it. The 'Next' button isn't greyed out so it is allowing you to continue.
  • cstanton
    0 cstanton over 2 years ago in reply to beacon_dave
    "Driver signature enforcement" is enabled by default in Windows and Windows will not let you use installed unsigned drivers. You either have to disable it on boot whenever you want to use the driver or disable it via group policy. There's also the option to use bcedit to disable integrity checks.
