Internet of Things
Internet of Things
Forum Anyone used Matter for home lighting, etc.?
  • Subscribers 522 subscribers
  • Views 63 views
  • matter
Fred27
Fred27 2 hours ago
Has anyone had experience of using Matter for home lighting, automation, etc.? I've just decided to replace my Philips Hue lighting with Ikea's Matter ecosystem. My reasoning for this is two-fold:
  • Whilst Zigbee is supposed to be a mesh, it doesn't feel like it. My 60s house has metal ducting for heating and this seems to cause problems for wireless stuff. My previous Philips Hue / Ikea Trafri system seem to have devices become frequently unavailable - especially those further from the hub.
  • It is possible to create custom Zigbee devices (with a well-known leaked key), but Matter seems better supported and future-proofed.
So far I had a little bit of initial instability which I've put down to devices updating firmware. Other than that it seems fairly solid. I'm starting with Ikea's Dirigera hub for now. I might jump to Home Assistant later, but wanted to keep it simple until it's proven to be working, stable and wife-acceptable. Ikea have a good returns policy so if their stuff is junk it can all go back. Right now it's a hub, 27 bulbs, 8 switches and a temperature sensor all from one manufaturer. Other than being a larg(ish) setup and spread over a 2.4GHz wasteland it should be low risk.
As far as geeking out and expanding it, it was pretty easy to build the Nordic Matter light bulb sample on an nRF52840 and integrate that. My long term plans would be the potential for some custom sensors (doors being locked rather than just closed), actuators (hot air heating vents) and garage door openers (which Matter surprisingly does not support natively).
Anyway, enough rambling from me. Anyone else using Matter?
  • JL85FR
    JL85FR 2 hours ago
    Hi Fred,
    At this time, I have an Homeassistant at home, wife compatible (I have designed a simple page with a summary of all important devices value, alowing to manage several thing depending on the solar panel production)
    I'm using TPlink Tapo devices, an esp32 DIY solar router, an esp32 custom device to supervise a rainwater tank level ( both ESP32 using MQTT protocol), and have recently purchased a Sonoff Matter compatible din rail module, but not yet implemented, I must first install a Matter server on my linux (raspberry pi) machine.
    The idea is also to avoid any kind of 'cloud controled' device... We have a connected Samsung fridge, but at this time the data (internal températures mainly) is no more available on my Homeassistant, the Samsung server that was sending data at the beginning.... but now it does no more... reinstalling the HA integration had no effect.
    I will post here when the sonoff device will be working if you have an interest.
    I recommend Homeassistant, it's a great product.
  • Fred27
    Fred27 1 hour ago in reply to JL85FR
    I'm definitely interested in your experience. I googled you Sonoff module and noticed it's matter over WiFi. That reminds me that some of my interest in this new setup is really Thread (transport layer) rather than the Matter side (application layer).
    According to Wikipedia Thread is based on 6LoWPAN. I looked at 6LoWPAN a while ago and found it confusing. So far at least, Matter over Thread seems easier to get started with - mostly aided by the Nordic examples.
  • cstanton
    cstanton 1 hour ago
    People who attended  How To Build A Smart Home Device With Matter might have :)
    It sounds like your problem's more around needing to do a wireless site survey though, that's a lot of bouncing and interference potential.
    Is it possible to setup a device that records signal strength or using an RF monitoring type device?
  • Fred27
    Fred27 1 hour ago in reply to cstanton
    Of course! I couldn't attend that live, and has problems watching on demand. To be honest, the examples are probably enough and I suspect the webinar was likely a walk-through of these. I might try watching on demand again...
