Internet of Things
Internet of Things
Documents lightweight cryptography documentation
  • Author Author: mr.osint
  • Date Created: 31 Jan 2016 1:22 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 8:47 PM
  • Views 1395 views
  • Comments 5 comments
The tight cost and implementation constraints of high-volume products, including secure RFID tags and smart cards, require specialized cryptographic implementations. The authors review recent developments in this area for symmetric and asymmetric ciphers, targeting embedded hardware and software
Reference:
A survey of lightweight-cryptography implementations
http://www.ei.rub.de/media/crypto/veroeffentlichungen/2010/08/08/lwc_survey_ieee_dtco2007.pdf
Lightweight cryptography (LWC) is a cryptographic algorithm or protocol tailored for implementation in constrained environments including RFID tags, sensors, contactless smart cards, health-care devices,Internet of Things (IoT) and so on.
Reference: Lightweight Cryptography for the Internet of Things -Masanobu Katagi and Shiho Moriai-Sony Corporation
( by mr.osint: as a technical point of  view "Lightweight" word  means the  cryptographic algorithm has smaller ciphertext than the others, for example
1)Using an ECDSA 256-bit key provides better security than RSA 2048, which significantly reduces the amount of data that needs to be transmitted between peers during the key exchange process of protocols like TLS, DTLS and IKE. This bandwidth savings is desirable for IoT devices or other end-entities that need to minimize bandwidth consumption over radio interfaces.
Reference: Provisioning X.509 Certificates Using RFC 7030- SEPTEMBER 2014 | ISSUE 245 | www.linuxjournal.com ,
2)This allows ECC to achieve the same level of security with smaller key sizes and higher computational efficiency; ECC-160 provides comparable security to RSA 1024 and ECC-224 provides comparable security to RSA-2048 ... We plan to continue our work on small devices towards a complete lightweight implementation of the security protocol SSL/TLS.
Reference: Comparing Elliptic Curve Cryptography and RSA on 8-bit CPUs - Nils Gura, Arun Patel .... Sun Microsystems Laboratories
https://www.iacr.org/archive/ches2004/31560117/31560117.pdf
sharing your knowledge
  • cryptography
  • internet of things
  • lightweight
  • iot
  • ecc
  • mr.osint
    mr.osint over 10 years ago in reply to mr.osint
    the degree of Doctor in Engineering-2015
    Lightweight PUF-based Key and Random Number Generation
    https://securewww.esat.kuleuven.be/cosic/publications/thesis-254.pdf
    Physical unclonable function:
    https://en.wikipedia.org/wiki/Physical_unclonable_function
    http://www.nxp.com/documents/other/75017366.pdf
  • mr.osint
    http://ece.gmu.edu/coursewebpages/ECE/ECE646/F14/project/F11_Project_Resources/Peris_Lopez_PhD.pdf
    Ph.D. THESIS
    Lightweight Cryptography in Radio Frequency Identification (RFID) Systems
    'An initial study and analysis of the state of the art identifies the need for lightweight cryptographic solutions suitable for these very constrained devices. From a purely theoretical point of view, standard cryptographic solutions may be a correct approach. However, standard cryptographic primitives (hash functions, message authentication codes, block/stream ciphers, etc.) are quite demanding in terms of circuit size, power consumption and memory size, so they make costly solutions for low-cost RFID tags. Lightweight cryptography is therefore a pressing need.'
  • mr.osint
    wolfssl :  lightweight SSL/TLS library | Embedded SSL Library
    for Applications, Devices, IoT, and the Cloud Providing secure communication for IoT, smart grid, connected home, automobiles, routers, applications, games, IP, mobile phones, the cloud, and more.
    wolfSSL (formerly CyaSSL or yet another SSL) is a small, portable, embedded SSL/TLS library targeted for use by embedded systems developers
    https://www.wolfssl.com/wolfSSL/Home.html
    https://wolfssl.com/wolfSSL/download/downloadForm.php
  • mr.osint
    Lightweight ciphers
    Lightweight cryptography - section of cryptography, which aims at the development of algorithms for use in devices that are not able to provide most of the existing codes and have sufficient resources (memory, power, size) for the operation.
    The use of lightweight cryptography
    Most modern algorithms designed for use as part of a computer software systems without hardware optimization software. This fact makes it impossible to use most of existing cryptographic algorithms in devices with limited processing power, small volume and low power consumption. Methods of cryptographic protection of data in systems with low cost became the basis of lightweight cryptography.
    Lightweight cryptography becomes relevant in the situation with "Internet of Things", which is a wireless self-configuring network between objects of different classes, that can include appliances, vehicles, smart sensors and RFID-tags (RFID).
    Often developers of lightweight algorithms are forced to choose between the two, sometimes mutually particular requirements for algorithms: safety, cost and productivity. In practice, it is easy to optimize any two of the three design goals: safety and cost, safety and productivity or the cost and performance, but it is very difficult to optimize all three design goals simultaneously. In this regard, there are many implementations of lightweight cryptography algorithms: both software and hardware. They have different and sometimes conflicting characteristics.
    http://cryptowiki.net/index.php?title=Lightweight_ciphers
    http://cryptowiki.net/index.php?title=Lightweight_block_ciphers
    http://cryptowiki.net/index.php?title=Lightweight_stream_ciphers
    Interaction of reliability, performance and price scheme
  • mr.osint
    Lightweight cryptography has been a very hot topic for the last few years, driven by the lack of primitives capable to run on devices with very low computing power. We can think for instance of RFID tags, sensors in wireless sensor network or, more generally, small internet-enabled appliances expected to flood the markets as the Internet of Things (IoT) arises.
    What is Lightweight Cryptography?
    At the core of lightweight cryptography is a trade-off between lightweightness and security: how can we reach high levels of security using only a small computing power? Many cryptographers have addressed these issues by suggesting lightweight streamciphers, blockciphers, hashfunction and recently one-pass authenticated encryption. We provide a discussion on the meaning of lightweightness in the following page.
    https://www.cryptolux.org/index.php/Lightweight_Cryptography
    see 'Lightweight Cryptography Lounge' and  'Software Implementation' sections
    (highly recommended)
    selected: https://www.cryptolux.org/index.php/Lightweight_Block_Ciphers
    a comprehensive documents by  Professor Alex Biryukov ( head of CryptoLUX)
    https://scholar.google.com/citations?user=tP5rH0wAAAAJ&hl=en
    https://www.cryptolux.org/index.php/Alex_Biryukov
