Internet of Things
Internet of Things
Documents Help Us Put the IoT in Innovation: Part 2, Nodes
  • Author Author: spannerspencer
  • Date Created: 2 Jun 2016 10:33 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 8:50 PM
  • Views 2574 views
  • Comments 11 comments
Calling all InnOvaTors!
imageTwo weeks ago we shone the bright light of innovation in your eyes and quizzed you thoroughly on your process for designing an IoT solution. Now we're back, and asking you to elaborate on the nodes and sensors that would act as the eyes and ears of your Internet of Things platform.
Looking Back at Workflow
The results of our look at that InnOvaTors workflow has been a treasure trove of inventive direction.
"I'd want to intimately get to know what information is valuable, and to whom the information is valuable," shabaz explained in regard to his IoT design approach. "Determine the overall goal in detail and determine the actual information or results that would be needed to make this a success."
Instructorman advised that we must "Keep scalability in mind. The solution should work well for a single user and for the tens of millions of other users too," while beacon_dave sees two distinct angles reveal themselves during his design process; active and reactive requirements.
Now we're off on the journey, let's take a much closer look at the first leg of the InnOvaTors race; Nodes.
First, here's a quick reminder of the scenario your IoT solution is working to solve.
Design a Home Patient Monitoring System with Notification and Alert Capabilities
Background
Among the numerous types of innovations that are expected to be fostered by Internet of Things (IoT) technologies, smart-connected healthcare solutions will perhaps be the most important one for millions of elderly people who live alone. In the UK 3.5 million people over the age of 65 live alone, and almost 70% of the women in this age group. The U.S has a similar trend with 11.8 million, and nearly half of the women over the age of 75 living alone.
This number is expected to increase as the growth in people over age 65 is projected to double from 43.1 million in 2012 to 83.7 million in 2050, according to the U.S Census Bureau. Whether an elderly person lives alone by choice or necessity, this living arrangement can pose a potential health risk as physical and cognitive impairment becomes evident.
Your Challenge: Helping a Stroke Patient Who Falls
A typical example of the challenge that the elderly face while living alone is Mrs. Jones. She is 79 years-old and has been living alone successfully for ten years since her husband passed away. While she has not had any problems during this period of time, Mrs. Jones recently suffered a minor stroke that led to numbness in her extremities and an overall weakness in strength but did not appear to be life-changing until she began losing her balance and falling in her apartment
Mrs. Jones’s daughter suggested to her mother that it was time to consider moving into a nursing home for safety’s sake. Mrs. Jones dismissed the idea out of a desire to remain independent. Her daughter discussed this situation with Mrs. Jones's doctor who said her options were limited. Beyond a live-in caregiver, home nurse visits, or home monitoring systems, which had limited benefits as they are currently designed, there was little else to do.
Common Sensors
The design process is in place, so now it's time to get specific. Help us flesh out the sensor side of things by telling us what you'd use, and how you'd use it. Consider the following:
  • What kinds of sensors and nodes would you employ here?
  • How will the nodes or sensors be powered?
  • What type of connectivity will be used?
In the comments section below, we'd like to hear your thoughts and advice on the sensor side of an IoT solution. The advice, ideas and direction you provide here will ultimately wind up in front of suppliers, manufacturers and industry leaders at this year's Elektronica show, so don't hold back!
  • internet of things
  • sensors
  • nodes
  • innovators
  • iot
  • sensor node
  • Workshopshed
    Workshopshed over 10 years ago +1
    I can see two options, monitor the person or monitor the house. For the latter you could go for a camera/AI approach and which could be trained to look for people on the ground or knocked over furniture…
  • rscasny
    rscasny over 10 years ago in reply to shabaz +1
    I like your thought about building in intelligence the node/gateway to processing close to the source. My concern would be more power consumption.
    dougw over 10 years ago +1
    A) The things we want to know in this situation are: Where is the person What is the problem What is the status of the person - posture, vital signs, stress, etc. B) The things we want to do are: Notify…
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago
    One sensor I have just been playing with may be ideal for this, well actually several of them. https://www.youtube.com/watch?v=08KkZKV75wE
    I just completed a video on the TI BOOSTXL-SENSHUB and it has several good candidates
    MPU9150 9 axis motion detector (Or the 6050 6 axis one) includes accelerometer, gyro and magnetometer so could be set to detect a fall (Fast acceleration), continued motion using the gyro and accelerometer indicating a certain level of health
    The TMP006 can provide body and room temperature measurements as it required no physical contact with the measured object, again, giving a sense of personal health
    connection via a sub GHz radio to a local hub connected to the internet to alert response teams or a Cell module to call instead.
    the IR portion of the ISL29023 light sensor could be used to measure pulse rate and again alert if over or under a certain threshold
    A sub Ghz radio would permit lower power operation as the central "Connected hub" would or could be mains powered in the home., if connected to a call network to extend portability to beyond the home, then either bigger batteries or pehaps less requent updates to the response center would be in order.
    I would expect the node to "Report In" on a scheduled bases to ensure the response team is aware it is still operational and then as needed to report events.. If mobile then the addition of a low power GPS could be added to provide subject location but this of course is a much bigger drain than all the other components combined so may necessitate bigger batteries and more frequent charging.
    ALL of these devices run well under a few microamps during operation and therefore would be ideal for extended battery use, a Single LIPO or couple of AAA would last potentially several months if coupled with a low powered MSP430 MPU as an example.
  • rscasny
    rscasny over 10 years ago in reply to Robert Peter Oakes
    Peter,
    thanks for the comment. I was looking at NXP's sensor hub and was interested in how it compared to Ti's senshub in practical application. They both look similar. And they feature sensor fusion which seems like would be used in this instance. Have you used NXP? How did it compare to Ti?
  • rscasny
    Peter,
