Motors and Drives
Motors and Drives
Forum Driver Circuit for a Reciprocating Water Pump in a Medical Device
Join Motors and Drives to participate - click to join for free!
  • Replies 31 replies
  • Subscribers 74 subscribers
  • Views 1906 views
jw0752
jw0752 over 1 year ago
Hello Friends,
I am working on servicing a circuit board that is used in a Medical Dental sterilizer. The circuit boards used in this model of sterilizer seem to have a chronic problem with a circuit that drives a reciprocating water pump. Here is a schematic of the circuit that fails:
My question is what is the advantage to using this circuit configuaration to drive the pump? The gate of the N CH MOSFET turns on and pulls one leg of the load to the negative rail and also turns on the P CH MOSFET about 20 microseconds later pulling the other leg of the load up to the positive rail. While this seems to work quite well it seems to me to be an added complication to be switching both legs of the load. I am hoping for some insight into what the advantage might be in using this configuaration. The Rds (on) of the N CH is about 60 milli Ohm and the Rds of the P CH is about 13 milli Ohm. While I am not certain this is probably a Pulsed circuit as I suspect that the pump needs a Pulsed drive to properly function. My hope is that in better understanding the advantages of this circuit design I might be able to modify it to lower the present failure rate. Failure is usually a shorted P CH Mosfet, A Heat Destroyed N CH MOSFET and a Shorted D26 Diode.
Any insights you may have will be appreciated.
    michaelkellett over 1 year ago in reply to jw0752 +2
    Well, the circuit looks a bit weird - I can only think that it has evolved. On similar things I have wanted to protect the load against the low side MOSFET failing short circuit and added a high side…
    jw0752 over 1 year ago in reply to Jan Cumps +2
    Hi Jan, How have you been? I can't tell you how happy it makes me to see so many of the old gang still together.
    Jan Cumps over 1 year ago +1
    Is it possible that the fragile gate of G17 sees too much high (inductive generated) voltage, from motor via R103 and R100, when the motor switches off? Maybe hang an isolated scope between drain and gate…
    0 jw0752 over 1 year ago in reply to Jan Cumps
    Hi Jan,
    0 jw0752 over 1 year ago in reply to genebren
    Hi Gene,
    Thanks for searching the switching circuits for me. I have never seen this configuration before and when ones skill level is as low as mine the first thought is that the designer had some omnicient insight that is beyond me. I find Michael's suggestion that this is a design that has evolved from its original intention fascinating. When circuits are on high quality circuit boards in very expensive equipment the thought that they may be jury rigged from previous designs didn't occur to me.
    0 jw0752 over 1 year ago in reply to dougw
    Hi Doug,
    Sorry I haven't been around. I have missed you guys. It is hard to explain how life pulls us around and sends us down different paths.
    When I get the boards the D26 is shorted as is the Q17. The Q15 has suffered heat damage to the extent that it may be exploded. It would be relativey easy to put a snubber diode across the load and I may try that on the next board that comes in. Can you think of any scenario where the snubber diode would cause an undesirable side effect? I will not likely get any feedback. If it solves the problem I will just never see the board again. That would be good but it wouldn't satisfy my curiousity. Thank you for your help.
    0 dougw over 1 year ago in reply to jw0752
    If D26 is shorted and Q15 turns on, Q15 will see a large destructive current.
    The snubber diodes, like D26, need to be large enough to handle repeated inductive spikes. It Q15 is driven with some sort of PWM, there will be a lot of inductive spikes, which could add up to absorption of significant energy.
    0 michaelkellett over 1 year ago in reply to jw0752
    I made a mistake in the connection of D1.
    This is a better simulation (with the right circuit, similar diodes to yours for D1 and D2, possibly better values for the load).
    The currents in D1 and D2 are identical which is why you can only see I(D1).
    By adjusting the timing you can set the peak diode currents to Vsupply/Load R.
    D1 and D2 are rated at 1A, Q15 is a protected MOSFET and should be fine with 4A continuous current. Q17 can handle a lot more current.
    It looks as if the diodes are the weakest link but what they actually see depends on the timing, supply voltage and load parameters.
    LTspice is free - I can send the model if you would like it.
    0 jw0752 over 1 year ago in reply to michaelkellett
    Thanks Michael for taking the time to further investigate. I have the LT Spice program and I would welcome your model so I can play with it myself.
    I will look into the possibility of upsizing the snubber diodes.
    thanks
  • jc2048
    0 jc2048 over 1 year ago in reply to jw0752
    Hello John,
    I would think that the designer was familiar with this converter topology
    https://www.vishay.com/docs/91616/twoswitch.pdf
    In the case of the forward converter with a transformer, it guarantees the magnetic reset of the core (with PWM less than 50%), stopping it stepping to saturation, and has a small benefit in recycling much of the magnetizing and leakage energy back to the supply (and thereby lowering the dissipation in the 'snubber' components). I suppose those might also be of benefit with PWM-ing a solenoid, but it's not an area I'm familiar with.
    Are you sure there is no other connection to the top of what looks like it has to be a current-sense resistor (the 0.22R)?
    LTSpice file here:
    https://www.dropbox.com/scl/fo/876wu0j1vuus2e9t4yz0k/ABlNGiq6fHZOnWuOwdkZHkI?rlkey=9rs366j5r73tu3lft7f4a8rgg&dl=0
    0 DAB over 1 year ago
    Hi John,
    I am glad you are back.
    I hope you are doing well.
