Motors and Drives
Motors and Drives
Forum Driver Circuit for a Reciprocating Water Pump in a Medical Device
Join Motors and Drives to participate - click to join for free!
  • Replies 31 replies
  • Subscribers 74 subscribers
  • Views 1904 views
jw0752
jw0752 over 1 year ago
Hello Friends,
I am working on servicing a circuit board that is used in a Medical Dental sterilizer. The circuit boards used in this model of sterilizer seem to have a chronic problem with a circuit that drives a reciprocating water pump. Here is a schematic of the circuit that fails:
My question is what is the advantage to using this circuit configuaration to drive the pump? The gate of the N CH MOSFET turns on and pulls one leg of the load to the negative rail and also turns on the P CH MOSFET about 20 microseconds later pulling the other leg of the load up to the positive rail. While this seems to work quite well it seems to me to be an added complication to be switching both legs of the load. I am hoping for some insight into what the advantage might be in using this configuaration. The Rds (on) of the N CH is about 60 milli Ohm and the Rds of the P CH is about 13 milli Ohm. While I am not certain this is probably a Pulsed circuit as I suspect that the pump needs a Pulsed drive to properly function. My hope is that in better understanding the advantages of this circuit design I might be able to modify it to lower the present failure rate. Failure is usually a shorted P CH Mosfet, A Heat Destroyed N CH MOSFET and a Shorted D26 Diode.
Any insights you may have will be appreciated.
    michaelkellett over 1 year ago in reply to jw0752 +2
    Well, the circuit looks a bit weird - I can only think that it has evolved. On similar things I have wanted to protect the load against the low side MOSFET failing short circuit and added a high side…
    jw0752 over 1 year ago in reply to Jan Cumps +2
    Hi Jan, How have you been? I can't tell you how happy it makes me to see so many of the old gang still together.
    Jan Cumps over 1 year ago +1
    Is it possible that the fragile gate of G17 sees too much high (inductive generated) voltage, from motor via R103 and R100, when the motor switches off? Maybe hang an isolated scope between drain and gate…
  • dang74
    0 dang74 over 1 year ago in reply to michaelkellett
    I am with you on the diodes being the weakest link.  I was tempted to suggest ditching the diodes altogether, but Doug later mentions that they act as snubbers and absorb spikes... so maybe using diodes with a higher rated current as he suggests is the best way.
  • robogary
    0 robogary over 1 year ago in reply to dang74
    Think some small snubber cap could help if there is excessive rate of rise on the switch?
  • robogary
    What's the power source voltage? Is it from a switched supply or a linear regulated ?
  • dang74
    0 dang74 over 1 year ago in reply to robogary
    I don't have any specific design experience in this area, but a flyback transformer circuit I was looking at did indeed use capacitors in the snubber.
  • colporteur
    0 colporteur over 1 year ago in reply to javagoza
    I learned something. Now where to put it so I don't forget it.
    0 jw0752 over 1 year ago in reply to jc2048
    Thanks for your reply, sorry for my absence from this thread. I am a bit over loaded now days. That circuit you posted sure looks close to what I have drawn. I don't have a board right now but three will arrive by weeks end and I will look more closely at the 0.22 resistor and connections to it. I thought it was just a current limiter but it will be best if I make certain.
    0 jw0752 over 1 year ago in reply to dougw
    I now have GS2M 2 Amp diodes in stock for future repairs.
    0 jw0752 over 1 year ago in reply to DAB
    Thanks - I was very please to see you are still helping people on the forum. Please give our greetings to your wife. Is shee still painting?
    0 jw0752 over 1 year ago in reply to robogary
    I will get this information when the next boards arrive.
    0 DAB over 1 year ago in reply to jw0752
    Hi John,
    She is not painting, but has become active with Zendoodle.
    I have been doing a lot of timelapse photography with some GoPro camera's I picked up.
    Got some great Aurora shots last year.
