Open Source Hardware
Blog Building compact size cubic micro-atx PC case from plexi and 3D printed parts
  • Author Author: jgrzybowski
  • Date Created: 22 Jan 2022 11:14 AM Date Created
  • Views 2305 views
  • pc
  • micro-atx
  • cubic
  • case
jgrzybowski
jgrzybowski
22 Jan 2022
Goal
+ cheap PSs dedicated for special purposes (like VHS grabbing and video compressing);
+ based on standard size components (for excellect ratio efficiency / cost);
+ as small as possible for easy hiding in cabinet;
Project realisation:
* On following pictures has been shown some major assembly steps;
* Plexi has been used as a main material (laser cut);
* Assembly was possible due to many 3D printed fittings and holders;
* Compact size has been reached (two pcs fit into the cabinet), on picture is shown paper sheet size A4 for comparison;
Pros: cheap, quite powerful (desktop equipment), small compact size;
Cons: quite noise due to tight inside, only for CPUs with TDP less than 90W (big size coolers are not possible to assembly);
image image image image image image image  image
    DAB over 4 years ago
    Nice build. The parts look very clean.
