Open Source Hardware
Blog Design a romantic PCB using a free PCB design tool - EasyEDA
  • Author Author: hadleywhite
  • Date Created: 5 May 2016 12:21 PM Date Created
  • Views 2381 views
  • romantic pcb
  • circuit design
  • easyeda
  • design pcb
hadleywhite
hadleywhite
5 May 2016
Have you ever tried to design a romantic PCB for your lover or an interesting PCB for your children or friends on special day? Why not? PCB also could be an amazing gift which comes from your creativity. Here I’d like to share a romantic and practical PCB to you.
This romantic LED board consists of 35 Flash LEDs and a  CR1220 battery cell and of course some resistors to limit the flow of current Since this circuit is no more than 35 LED’s and resistor arrays even beginners can try this PCB out and make a beautiful gift
The circuit is very easy to understand and very few components are required to build this flash LED circuit. https://easyeda.com/editor#id=XVd7NHmgW
LED-Merry Me_SCH
When PCB layout is completed on EasyEDA, it looks monotonous so it still needs more steps to make it vivid and nice.
You could click the ‘image’ button in the PCB Tools menu on EasyEDA, and select an image in the new window of ‘Insert Image to PCB’, also, you can use Color Tolerance or Simplify Level function to adjust your image. When complete the above steps, you could press the button ‘Insert Image to PCB’, then you will see your image that have been already inserted to PCB.
Next, move the inserted image to the left of PCB, you can see and edit it online at
https://easyeda.com/editor#id=MOI0UcuoG
Of course, you can change the layer you like and insert the image you like.
You can access the PCB design of this Romantic PCB board through this link
https://easyeda.com/Luo/Design_a_romantic_PCB_with_flash_LED-MOICwOI0h
If you want to gain this romantic PCB, you also could directly order it from EasyEDA. Just need to click “Fabrication Output” button then redirect to the page of “PCB order”. In that page you can place an order quickly and easily.
Finally, fill in the form, save to cart, and complete you order, then you will get your PCBs a few days later.
If it’s the first time you notice and use EasyEDA which is the keynote of the above design, you could learn how to use EasyEDA quickly and easily after reading the tutorial. The tutorial is completed with videos that explain the operations, such as the diagram creation. About EasyEDA, it is is a free, web-based and easy-to-use EDA tool integrating powerful circuit design, mixed-mode circuit simulator and PCB design. EasyEDA is designed to give electrical engineers, educators, engineering students and electronics hobbyists an Easier EDA Experience.
The followingbriefly presents the features of EasyEDA tool.
    Great!
    I have sen this romantic PCB first time.
    Really useful in art and designing projects.
