Open Source Hardware
Blog Front Panels! How to Label them
  • Author Author: shabaz
  • Date Created: 27 Mar 2015 4:19 PM Date Created
  • Views 4597 views
  • Likes 9 likes
  • Comments 29 comments
  • labelling
  • metal_enclosures
  • enclosures
  • front_panel
  • hammond
shabaz
shabaz
27 Mar 2015
Front panels can cost a lot. As an alternative I had a theory that I put to the test this week, and it worked out well. The theory was that for home-built projects, surely trophy/jewellery type engraving could be used for labels.
It turns out that it can be done on enclosures in most high streets/malls as a same-day service - just using the engraving services of a key cutting or jewellers store : )
In the UK, the chain 'Timpson' was used here, on this aluminium enclosurethis aluminium enclosure (these Hammond aluminium enclosures are really great - simple, with a nice finish):
It was very efficient. I just told them the text I wanted and where, just written on a piece of paper along with a quick 30-second pencil sketch.
They figured out how to center it, the font size, etc., based on their experience with their tools.
I think they did an awesome job!! I'll be going back to Timpson for future projects.
  • D_Hersey
    D_Hersey over 11 years ago
    Hi,
    This is eighth inch (3.175 mm) glazing plastic from the hardware store.  I bought some better, colored stuff from Petersen Bros scrap bin.  Will post pics!
  • Problemchild
    Problemchild over 11 years ago in reply to D_Hersey
    The 1/8"  is pretty standard we have 3mm here which is more like 2.8 ish  even so that's a bit thick to draw about something 1-2 mm would be better by Acrylic is a bit brittle if thin and Poly Carb doesnt really lase unless you class going up in flames "lasering " image
  • Problemchild
