Open Source Hardware
Blog Front Panels! How to Label them
  • Author Author: shabaz
  • Date Created: 27 Mar 2015 4:19 PM Date Created
  • Views 4316 views
  • Likes 9 likes
  • Comments 29 comments
  • labelling
  • metal_enclosures
  • enclosures
  • front_panel
  • hammond
shabaz
shabaz
27 Mar 2015
Front panels can cost a lot. As an alternative I had a theory that I put to the test this week, and it worked out well. The theory was that for home-built projects, surely trophy/jewellery type engraving could be used for labels.
It turns out that it can be done on enclosures in most high streets/malls as a same-day service - just using the engraving services of a key cutting or jewellers store : )
In the UK, the chain 'Timpson' was used here, on this aluminium enclosurethis aluminium enclosure (these Hammond aluminium enclosures are really great - simple, with a nice finish):
It was very efficient. I just told them the text I wanted and where, just written on a piece of paper along with a quick 30-second pencil sketch.
They figured out how to center it, the font size, etc., based on their experience with their tools.
I think they did an awesome job!! I'll be going back to Timpson for future projects.
    jw0752 over 10 years ago in reply to shabaz +2
    Beautiful final result. John Different subject but the "RF Circuit Design" by Chris Bowick has arrived and I am really enjoying reading it. Thanks for your recommendation. John
  • fvan
    fvan over 11 years ago +1
    That's an excellent idea, the result looks great!
    jw0752 over 11 years ago +1
    Another great idea from the workbench of Shabaz. Thanks for sharing. John
    shabaz over 11 years ago in reply to Problemchild
    It would be interesting to see how anodisation works on some popular cases like the Hammond ones.
    I was thinking of mixing some black pigment with watery epoxy resin, use a pippette to place it on the text, wipe off with a credit card and then wait for it to cure. Not sure how well it would stick. It might be worth an experiment on some scrap aluminium.
  • D_Hersey
    D_Hersey over 11 years ago
    I'll be happy to share the files, once I figure out how.
  • Problemchild
    Problemchild over 11 years ago
    Ordered some stuff to do my own Anodisation you can put on resists or say vinyl lettering to make the letters up maybe even dye the case afterwards.
    I fancy a Tie die colour case ..well freaky
  • Problemchild
    Problemchild over 11 years ago in reply to D_Hersey
    The 1/8"  is pretty standard we have 3mm here which is more like 2.8 ish  even so that's a bit thick to draw about something 1-2 mm would be better by Acrylic is a bit brittle if thin and Poly Carb doesnt really lase unless you class going up in flames "lasering " image
  • Problemchild
    nice set of shapes do you have the DXF or what ever was used for that ?
