Open Source Hardware
Blog Hacking / Trouble shooting / Field installation tool
  • Author Author: R_Phoenix
  • Date Created: 31 Mar 2011 12:10 PM Date Created
  • Views 983 views
  • rs-232
  • can_bus
  • adaptor
  • serial
  • data
  • communication
R_Phoenix
R_Phoenix
31 Mar 2011
RP-2ADP
The RP-2ADP is an adaptor for infield wiring of the DB9 Serial connector.
Allow easy access to the TX, RX, and Ground pins.
The RTS and DTR pins (Pins 4 and 7) are also available for CAN bus or port powered devices.
* Available in male or female configuration.
* Tab for wire strain relief.
* Mounting Hardware included.
* Accepts 24 - 16 awg size wire.
* Push button Spring-Cage Terminal block make easy secure wire connections.
Available at Phoenix Engineering.
  • R_Phoenix
    R_Phoenix over 15 years ago
    Male and Females now available.
    http://www.royalephoenix.com/pe_shop/index.php
