Open Source Hardware
Blog New parts, new part PCB Problem
  • Author Author: camuyano
  • Date Created: 15 Mar 2015 7:34 PM Date Created
  • Views 2912 views
  • Comments 8 comments
  • eagle
  • eaglecad
  • cardsoft
  • oshw
  • sparkfun
  • cardsofteagle
  • sparkfun;
  • eaglecad;
camuyano
camuyano
15 Mar 2015
I had a wake up call using Eagle Cad and a third party libraries. And I wanted to share how my ignorance caused my boards to fail (for now).
Just for reference the board uses an Atmega328P SMD and i wanted a smaller and cheaper part than a normal crystal. So I went with a resonator, there are a few very cheap and very small. I am not that good on creating parts layout by myself so I searched on the libraries at hand for a resonator with the footprint similar to the one I wanted to use. And very quickly I found a smd resonator on Sparkfun-FreqCtrl library and the part is RESONATOR-SMD. First I was very happy to actually found this part. So I put the part on my PCB and send it to fab for manufacturing. The board came back beautiful red (I had to pay a little more for color selection). Then I notice that around the resonator there were some solder mask missing, but said to myself this must be a size limitation from that cheap Chinese fab. I am like a little kid whenever I get mail, so I ran to get my iron and started soldering. "No need to do any measurement, I am 99.9% sure the design is correct" I said. If fail then I will test, but I wanted to solder right away. So I did.
Latter after the boards start failing I then went back and did some measurement, just to find some missing solder mask and some exposed copper. The copper exposed then again I thought at first it was because of Chinese fab, but turn to be my mistake not the fab.
Lets see the picture bellow, look the black region is missing red solder mask. And at the borders you can see exposed copper (blue arrows). The missing solder mask (black part) does not causes any problem. However the exposed copper do. It causes my resonator to short to ground making my board fail.
And what was the cause of all? The actual part on the library had instructions to be constructed exactly as it was done. There is a layer in eagle called tStop. The tStop layer is the one that allows solder areas of copper to be exposed. This layer stops solder mask in a specific area. This part has a rectangle over the entire part. The size of this rectangle plus a small isolation in the board causes this tStop rectangle to go over my ground plane, and causes the copper to be exposed. On the image bellow, the big white hatched rectangle is the tStop that caused the problem. This made my twenty boards order to fail.
I have three options:
1. Etch (manually)  out that exposed copper to a distance that I can solder the part
2  Cover with heat resistant tape the exposed copper
3. Paint it over with solder mask (that I do not have at hand).
I am going to get a few pieces of tape, and try to cover the exposed copper in order for me to use these boards. But anyhow I edited my design and send a few more to be made, this project need to be finished and quickly. In about two weeks I should be getting them back and hope this issue is water under the bridge.
Hardware design has its ups and down, but it is well worth it. You win some and loose some and learn a lot during the process.
I should try to contact SparkFun about the part, or submit a pull request with the fix. I am a noob, this might be the right design and I am the one mistaken. Anyhow for PCB with a big ground plane close to this part this is not working. My guess is that the rectangle is intended to avoid ground plane under the part and not to stop the solder mask. This must be a layer mistake.
For the new PCB I did a ground plane cutoff polygon around the resonator, removed the tStop from the part and made the side contacts a little bigger (for easier soldering). When I get the PCB back from fab will post again with the new board. Hope that it work.
This PCB eagle files are not posted now, because this board is for a surprise event. After the event all will be posted. If you want to know, the board is just a usbaspLoader using an Atmega328P with an Arduino header footprint. Nothing revolutionary. Oh and of course, instead of a crystal with two capacitors it is using a 16Mhz resonator.
  • camuyano
    camuyano over 11 years ago
    Final boards came in, and now they are looking great.
    I modified the part footprint a bit for my resonators to work. Since I have not much experience, I did not wanted to move the other pads closer to the middle. Instead I made them wider, that but wider enable me to use my resonator. This might not be a high quality join but it gets the job done. Here is a picture of the resonator in the fixed board.
    I also added a cutoff of the ground layer around the resonator just in case, that's why the surrounding area looks dark green.
    Overall I am very happy with the results. Modifying a part in Eagle was a great learning experience. And I say to others, if your part is not exactly in Eagle you can improvise and create it, just look for a similar part and start modifying.
    e14 Contributor over 11 years ago in reply to camuyano
    Hi Javier,
    Nice work! Glad to hear your final design worked out. Indeed the best way to learn Eagle library work is to dive right in. For anyone that might like a little more guidance, or simply wants somewhere to start, please feel free to check out our online tutorials.
    Here is a page that contains all of our eagle tutorials:
    https://learn.sparkfun.com/tutorials/tags/eagle
    And here is a tutorial specifically working within an eagle library:
    https://learn.sparkfun.com/tutorials/designing-pcbs-smd-footprints
    Hope this helps!
    PS. I did notice that your traces off the resonator look a little long (can't see the IC in the picture above). We usually try to keep those traces between the resonator and the IC as short as possible. It sounds like it worked out just fine for ya, but it might be something to keep in mind for future layouts.
    Hi Javier,
    Hope this helps!
  • camuyano
    camuyano over 11 years ago in reply to e14 Contributor
    You my friend are correct it should be closer. Also since I do not know how to solder and measure very well what I did is enlarged the outside pads to fit my resonator. My part works and it is easy to solder, but it could be better. From the picture you can see it is not perfectly aligned. I am learning as I go. I am already in the process of building the boards, so for this one, I hope  it is not an issue but it has to stay this way. Here is a picture of this same board as well as an album of the almost final version of the board.
    A gallery of picture of the almost final version of the board is here:
    https://plus.google.com/photos/114378675842551786487/albums/6136495950227474657
    This board will be the badge for a convention we are hosting this may in Puerto Rico. Is BSides Puerto Rico, and the convention may be about Infosec but we are trying to get people involved in hardware as well. So we hope giving away an Arduino compatible badge to every participant ignite the creativity spark we all have deep inside.
    It is pretty much a USBAspLoader board but with a little sprinkles of my inexperience to make it our own.
    To get people attention we have a simple keyboard emulator sketch video where the boards sends Win+R and opens notepad and starts typing stuff.
    here is the video for it:
    Again, thanks for all your comments, your reply means a lot to me.
