Open Source Hardware
Forum Archaeology Resistivity Meter
  • Replies 332 replies
  • Subscribers 332 subscribers
  • Views 56243 views
  • armp
  • archaeology resistivity meter
kltm
kltm over 6 years ago
Hi I'm looking for ideas on an update to a resistivity meter for archaeology. The only published designs for diy were in 2 magazines. One was published in 1997 and the other in 2003. I have copies of both articles available. The reason behind this is the current high cost of available equipment, usually well beyond the reach of most archaeological groups. I've attached a basic block diagram. In the first magazine article the meter is very basic. It relied on the operators to write down the reading given as the survey was taken. Given that a normal survey grid is 20m x 20m and 1 reading is taken on every sq mtr there would be 400 readings to write down and then input into a program used to interpret the results. The later article is really an update to the first where a PIC has been added to record the readings. This again is prone to error, because eadings are taken manually by pressing a button.
I'm sure given the advances in electronics there must be better ways.
  • kltm
    kltm over 6 years ago in reply to michaelkellett +8
    Hi Michael This all sounds very interesting and encouraging. I see you have found the original article, the update is also on slideshare somewhere. I haven’t really thought much about cost, but as you…
    michaelkellett over 6 years ago in reply to shabaz +7
    I can't live with that - I have to have symmetry The problem is that the Howland current pump doesn't constrain the voltage on the load at all when perfectly balanced - and my LTSpice model is unrealistically…
    michaelkellett over 6 years ago in reply to michaelkellett +7
    AS promised - now for the phase sensitive detector. I couldn't easily model this in LTSpice, which is no great surprise because it needs multiplication and square roots. I used Simulink in MATLAB - which…
  • kltm
    Hi all should I have a go at creating a group as suggested?
    Ken
    michaelkellett over 6 years ago in reply to kltm
    I think a group would be good, we're up to 222 posts now, and maybe 10% of the journey completed at most.
    2500 post will be slow to trawl through !
    shabaz over 6 years ago in reply to kltm
    Hi Ken,
    It might be best to contact cstanton just in case there are bits of Jive config/magic that need to occur.
  • kltm
    kltm over 6 years ago in reply to cstanton
    Hi Christopher
    I would welcome your assistance in helping to set up a group for this project please.
    Ken
  • cstanton
    cstanton over 6 years ago in reply to kltm
    I need to know:
    - Who will administrate the group
    - Whether it should be publicly visible, or private
    - Depending on that, whether or not there is a list of people (links to their profiles or of their usernames are useful) who you want to be able to create content in the group, for example you might want a limited set of people to create discussions and blogs and documents, but only allow the public to comment on them.
    - If you have a preference for 'where' the group is listed or created on the site, which will be taken into consideration
    This can be sent in a private message.
  • kltm
    Hi Chris
    I will be the administrator and a public visible group would be preferable. Requests to join the group should be automatically accepted. Once a member of the group they would be welcome to contribute.
    Thank you
    Ken
    • Vote Up +5 Vote Down
  • cstanton
    Ok, how about start using the group Maker, Hacker, Inventor and Hobbyist for the content, and when there becomes too many blogs/discussions/posts in there on the topic of this device, I'll setup a group and move the content to a dedicated group?
  • kltm
    Hi Chris
    I would rather go straight to a group if possible. We have had over 220 posts so far on this thread and we are only about 10% of the way through the project. It's proving to be quite popular.
    Ken
    I'm inclined to agree, I looked at the group cstanton suggested and it has quite a bit of content - it would be very hard to sort out Earth Reistiance material from other things.
  • cstanton
    I understand where you're coming from, and this suggestion I make is because:
    1. There's 220 posts, but they're all comments, not separate blog posts, documents, videos, etc.
    2. It gives the people involved somewhere to post until the group is setup and ready, and it's trivial to move content around, especially if you put a tag on it denoting what it's for.
    So I'm weighing up here how much content will actually be created versus the time it takes to create the actual group versus giving somewhere that can be used in the mean time. This's a short term compromise.
