Open Source Hardware
Forum Novel wire stripper
  • Subscribers 328 subscribers
  • Views 777 views
  • diy
Novel wire stripper
fustini
fustini over 14 years ago
Howdy,
I just saw this novel wire stripper on Make blog.  It's another example of the cool open source 3D-printable designs on Thingiverse:
http://blog.makezine.com/2012/01/30/electro-wire-stripper/
http://makezineblog.files.wordpress.com/2012/01/wirestrpper.jpg?w=580&h=435
Cheers,
Drew
  • ntewinkel
    ntewinkel over 14 years ago
    That is really neat! - the light comes on when you've cut through the insulation, how clever image
  • R_Phoenix
    R_Phoenix over 14 years ago in reply to ntewinkel
    Only one issue. Once you've nicked the wire, the strands (or solid copper) break easily.
    You shouldn't need 2 cut the insulation completly to strip it off.
    DAB over 14 years ago
    I like the simplicity of the design.
    As for nicking the wire, you could use a piece of tape across the blades just above the cut through point and use a twisting motion to get past that issue.  I used to work on military gear and a nicked wire was unacceptable.
    e14 Contributor over 14 years ago in reply to DAB
    What is better than the LED is a small sounder, that way no need to watch anything other than the cutting itself.
    regards
    Andy
    PS. You could actually fit both.......
