Open Source Hardware
Forum Any affordable mini computer available in the market?
  • Answers 3 answers
  • Subscribers 326 subscribers
  • Views 1415 views
  • raspberry
  • minicomputer
  • robot
  • affordable
  • microcontroller
  • iot
  • business
  • hacking
Well, I am a noob in this electronic kind of stuff but have an idea in my mind. What I'm planning is make a mini-computer using any microcontrollers like the Arduino Uno board or the Raspberry Pi (may be 2 or 3).
What if we make a mini-computer, no matter with Arduino board or maybe raspberry, And try to bring it in the market?
Will it bring or cause any violation rights or something? I mean will it be illegal if I make a mini-computer with any of the existing microcontrollers and bring my mini-computer in the market to sell it?
And if no, then any ideas for making one which is NOT a common one?
Thanks in Advance!
  • clem57
    0 clem57 over 10 years ago
    You can if you do not name it "intel minicomputer" or use other names or trademarks.
    0 DAB over 10 years ago
    As @Clem said, as long as you are not competing directly with a known product and as long as you do not violate your main MCU intended use issues, you would be mostly free to create a product by integrating off the shelf components to make your mini-computer system.
    You would basically became a Value Added Retailer (VAR) for the devices, hence the need to avoid legal issues.
    If you want to go this route, I would get a system design together and then set down with a knowledgeable lawyer to make sure you are all above board.
    After that, it is a matter of building the prototype, establishing a cost per unit number and serve a market niche.  A Kick Starter effort will tell you if you have a device that would interest people.
    Either way, you will have a lot of challenges to overcome, so good luck.
  • amgalbu
    0 amgalbu over 10 years ago
    raspberry, arduino & c are open source hardware projects. In general, there are two broad classes of open-source licenses: copyleft and permissive. Copyleft licenses (also referred to as “share-alike” or “viral”) are those which require derivative works to be released under the same license as the original; common copyleft licenses include the GNU General Public License (GPL) and the Creative Commons Attribution-ShareAlike license. Other copyleft licenses have been specifically designed for hardware; they include the CERN Open Hardware License (OHL) and the TAPR Open Hardware License (OHL). Permissive licenses are those which allow for proprietary (closed) derivatives; they include the FreeBSD license, the MIT license, and the Creative Commons Attribution license. Licenses that prevent commercial use are not compatible with open-source; see this question for more.
    Please note that the open-source hardware definition is not a license, although it does describe some of the license terms which are compatible with the practice of open-source hardware.
    (From oshw site)
  • amgalbu
    BTW, may be you will find this interesting
    https://www.indiegogo.com/projects/nexdock-the-world-s-most-affordable-laptop--2#/
