Passive Components
Passive Components
Forum Male/female pin converter?
Join Passive Components to participate - click to join for free!
  • Replies 14 replies
  • Subscribers 112 subscribers
  • Views 5371 views
madbilly
madbilly over 6 years ago
Hi everyone,
First, this is my first post in element14 so I don't know if there is a better subforum for my question - if there is, then mods please move it there.
I'm trying to find some pin converters, by which I mean something which will change a male pin into a female socket. This is primarily for stacking shield boards on top of a microcontroller board when I've got the wrong sense pins soldered in and don't want to change them. For example, I have two boards which I want to stack, both have male pins, so how do I connect them? I've looked around a lot of sites trying to find these but haven't succeeded yet and when I was thinking of where I could ask element14 seemed like the logical choice.
Helpful suggestions much appreciated.
Cheers image
  • luislabmo
    luislabmo over 6 years ago +10
    Hello, I agree with others, maybe if you need an adapter for these kind of situations, pay good attention to the orientation, as usually parts that are stackable use stackable-female headers and most of…
    shabaz over 6 years ago +6
    Hi, I don't think such a thing exists (maybe it does as some hobby item but I've not seen it), but there are a few other options if you don't wish to remove the pin header from one of the boards. The simplest…
  • beacon_dave
    beacon_dave over 6 years ago in reply to shabaz +5
    "Another option is to get hold of a couple of header sockets, and solder them back-to-back. It would be an ugly solution though." If you use separate header shells and female inserts, then you could crimp…
  • colporteur
    colporteur over 6 years ago in reply to luislabmo
    Sounds like a voice of experience.
    My soldering career is long behind me. I assume the process of solder sucking  each pin individually with a good vacuum device doesn't work?
    I seem to recall this was the process for removing IC's. Now the pin on an IC moves slightly when pressure is applied. Maybe not so much with a connector leaving solder behind that binds.
    jw0752 over 6 years ago in reply to luislabmo
    Thanks Luis,
    I too have been searching for the double male headers for a long time. I had actually given up but your post identifying the vendor Pololu allowed me to find some. I have placed my order and I am happy.
  • luislabmo
    luislabmo over 6 years ago in reply to colporteur
    In my experience, it requires a good soldering pump to do it without extra effort -like you said. The popular solder pumps (the ones with nylon tip that most people have) will probably give you extra work image
    Luis
  • colporteur
    Those blue plastic single action pumps are fine for a small job but for professional solder removal a more robust device with a steady vacuum is required.
    I do like the idea of cropping the header before removal. Definitely make it easier removing a pin at a time.
