Passive Components
Passive Components
Forum LM 339 Comparator Question
Join Passive Components to participate - click to join for free!
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 111 subscribers
  • Views 3033 views
  • lm339
jw0752
jw0752 over 11 years ago
Does anyone know if the unused inputs of an LM339 quad comparator need to be stabilized and if so what is the procedure? Since the outputs are open collector I suspect it is ok to leave them floating. I have checked my data sheets but I can't find anything about the unused inputs.
Thanks John
    dougw over 11 years ago +1 suggested
    It should be okay to leave them floating - there should be no excessive current conditions, but it looks like the internal circuit might use a bit more current when the output is low - it is hard to tell…
  • johnbeetem
    johnbeetem over 11 years ago +1 verified
    I would suggest pulling up the unused +in and pulling down the unused -in. That way your open-collector outputs are switched off and there's no internal switching generated by noise. JMO/YMMV
  • D_Hersey
    D_Hersey over 11 years ago +1
    Often, John, upon a little meditation, we can find a use for those unused comparators. They can be used to set up a warning light with an LED, for example.
    0 dougw over 11 years ago
    It should be okay to leave them floating - there should be no excessive current conditions, but it looks like the internal circuit might use a bit more current when the output is low - it is hard to tell because the internal schematic does not show all components in the chip. If there is noise getting to floating inputs, it could cause random switching internally, which could inject some small noise on the power supply.
    Doug
    0 jw0752 over 11 years ago in reply to dougw
    Hi Doug,
    Thank you for the prompt reply. I use these LM339s all the time but most of the time the application is just an experiment and I don't mind floating inputs. This time the application is a little more important to me so I wanted to make sure that I was following proper protocols.
    0 DAB over 11 years ago
    Hi John,
    Even with an open collector output, you might want to ground the inputs just in case you get a static charge build up on the inputs.
    I would use jumpers so that you could use the devices at a later date if needed.
  • johnbeetem
    0 johnbeetem over 11 years ago
    JMO/YMMV
    0 jw0752 over 11 years ago in reply to DAB
    Hi DAB,
    Thanks for your input. Things hit a snag last night and I had to go back to the drawing board for the final piece to the DC Load project. Check out my blog tonight.
    0 jw0752 over 11 years ago in reply to johnbeetem
    Thanks John,
    This makes the most sense to me. The section will be turned off and stable.
  • D_Hersey
    0 D_Hersey over 11 years ago
    0 jw0752 over 11 years ago in reply to D_Hersey
    Hi Don,
    You are 100% correct. I already am eyeing the unused sections for a couple of add on applications.
  • D_Hersey
    Lotsa stuff you can do with comparators and discretes.  You can make a relaxation oscillator.  You can make any kind of logic gate, including majority gates.  I've made little SMPS controllers out of them when I needed a supervoltage, works well with switched-capacitor schemes.  With your OC type, you can get pseudo-complementary output with an active top-load (current source) SVP.
