Passive Components
Passive Components
Forum Need to replace resistor 900 ohms / % Tolerance
Join Passive Components to participate - click to join for free!
  • Replies 41 replies
  • Subscribers 108 subscribers
  • Views 11769 views
Alex-andre
Alex-andre over 3 years ago
Hello there,
I need to replace this resistor which appears to be a 900 ohm with a % tolerance. (4 rings = Black / White / Red / Silver or Grey and around 25mm long)
I bought one with almost same features (OHMITE OX102KE Through Hole Resistor, 1K ohm, OX, 1W, ±10%, Axial, 300V) but it doesn't fit, it's far too small compare to the one I need to replace. Do you have any suggestion where to buy or how to replace it ?
I attached a picture below.
Thanks a lot
Aleximage
    jw0752 over 3 years ago in reply to dougw +5
    Hi Doug, I'm doing good. Glad to see so many old friends still around.
    jw0752 over 3 years ago +3
    Based on my experience with this style relay it is highly probable that the resistor is across the Normally Open relay contacts and serves as a soft start to the load. As configured it would current limit…
  • Gough Lui
    Gough Lui over 3 years ago +1
    Do you have any information about the power rating? As long as the power rating of the replacement is the same or greater than the original, it doesn't really matter that it is physically smaller. You…
    0 Jan Cumps over 3 years ago in reply to jw0752
    You were missed.
