Passive Components
Passive Components
Forum Need to replace resistor 900 ohms / % Tolerance
Join Passive Components to participate - click to join for free!
  • Replies 41 replies
  • Subscribers 108 subscribers
  • Views 11759 views
Alex-andre
Alex-andre over 3 years ago
Hello there,
I need to replace this resistor which appears to be a 900 ohm with a % tolerance. (4 rings = Black / White / Red / Silver or Grey and around 25mm long)
I bought one with almost same features (OHMITE OX102KE Through Hole Resistor, 1K ohm, OX, 1W, ±10%, Axial, 300V) but it doesn't fit, it's far too small compare to the one I need to replace. Do you have any suggestion where to buy or how to replace it ?
I attached a picture below.
Thanks a lot
Aleximage
    jw0752 over 3 years ago in reply to dougw +5
    Hi Doug, I'm doing good. Glad to see so many old friends still around.
    jw0752 over 3 years ago +3
    Based on my experience with this style relay it is highly probable that the resistor is across the Normally Open relay contacts and serves as a soft start to the load. As configured it would current limit…
  • Gough Lui
    Gough Lui over 3 years ago +1
    Do you have any information about the power rating? As long as the power rating of the replacement is the same or greater than the original, it doesn't really matter that it is physically smaller. You…
  • scottiebabe
    0 scottiebabe over 3 years ago in reply to Jan Cumps
    Given the location of the resistor it's plausible it has fused open if the control circuitry glitched. Of course really given the information provided its not easy to say.
    Source: https://sound-au.com/articles/soft-start.htm
    I suppose one could reframe the question as how do you test a resistor without a multimeter. I suppose a coin cell and LED could make a simple test to see if the resistor failed.
    0 dougw over 3 years ago
    black-white-red-silver should be 92 ohms 10% tolerance (which is a bit strange, so it should be measured)
    It looks like a 2W, 3W or 5W resistor (I've seen all 3 ratings in this size)
    If it is a 24 V circuit, I would go with 5 W, If it is a 12 V circuit maybe 2 W is enough.
    0 dougw over 3 years ago in reply to Alex-andre
    The first 3 bands indicate value, the last band indicates tolerance - in this case silver = 10% tolerance on the resistor value.
    0 jw0752 over 3 years ago
    Based on my experience with this style relay it is highly probable that the resistor is across the Normally Open relay contacts and serves as a soft start to the load. As configured it would current limit the start until the relay closes and provides full power to the load. Before the relay closes the resistor will get hot. This resistor does not look failed and likely would test within its original nominal value. As recommended by others get a cheap multimeter and test the resistance to be sure. If you remove the resistor from the board you may find that the colors of the bands are in better shape on the underside in case you want to verify the original value. If I had to guess I would say that it is at least a 5 Watt resistor.
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to dougw
    thx
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to jw0752
    ok will do thx a lot
    0 dougw over 3 years ago in reply to jw0752
    Hey John, good advice.
    How are you? Been a while.
    0 jw0752 over 3 years ago in reply to dougw
    Hi Doug,
    • Vote Up +5 Vote Down
    0 michaelkellett over 3 years ago in reply to jw0752
    Are you back for while ?
    0 jw0752 over 3 years ago in reply to michaelkellett
    Yes, as much as I can. Not as much me time as I had before.
