Passive Components
Passive Components
Forum Can someone help identifying what this are? I reckon it is an old diod. Need something to replace it with
Join Passive Components to participate - click to join for free!
  • Replies 65 replies
  • Subscribers 105 subscribers
  • Views 10200 views
kardan
kardan over 2 years ago
imageimageimageTUAC TD500-C1 mono amplifier
TUAC TD500-C1 amplifier boardimage
The simple markings on photo does not have the Anode and Cathode marked.
Please reload the page as I have updated the last image.
  • geralds
    geralds over 2 years ago in reply to Ian-Scott +3
    Hi Ian-Scott Just I've rotated it for some readers. Best Regards Gerald ---
  • anniel747
    anniel747 over 2 years ago +2
    Deleted
    shabaz over 2 years ago in reply to anniel747 +2
    Could be.. I thought maybe the color code was brown-yellow-gray, 148, i.e. maybe 1N4148, but I've not seen that before. Anyway, hopefully photo(s) can make it clearer, or some context.
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to kardan
    And 1n4148 & 1n4002
  • Ian-Scott
    Zeners are next to the two box .1k 250 capacitors by the op amp
  • kardan
    0 kardan over 2 years ago in reply to Ian-Scott
    I have two 1k resistors and 150uF Capacitor, i see on yours there are one 2k resistor and 470uF Capacitor, and an extra 470 pF.
    By the Line in, you got 10uF and i have 0.22uF Polyester Film Capacitor .
    Wonder if there maybe should be an 470 pF between the two 1k resistors?
    You can see on the photo all the differences i discovered. Red markings seems to be the same as on yours, blue numbers are different
  • Ian-Scott
    I would assume yours in correct for that version unless it looks like they have been changed TUAC were continually changing circuit designs all through production. I have a TD500 I will try to get some pics the next few days.
  • Ian-Scott
    Were the 0r33 resistors ok. Out of curiosity have you checked all the output transistors ?
  • Ian-Scott
    +1 Ian-Scott over 2 years ago in reply to kardan
    The diodes you have marked as 1n4148 next to .1k 250 either side of the op amp I'm sure should be 15v zenners ?
  • kardan
    0.33, no.. they were about 4-6 ohms, all of them measured differently.
    The top one BC182B i got and it has one shorted leg. I waiting for a replacement for that.
    Same as the output transistor marked 14, Hfe should be at minimum 15.. Found an original with same labeling.
    I just found out that the 10 ohms by the 40871 are Wirewound. I will replace all of these type of resistors with Wirewound Cement Filled Ceramic.
    I thought before that these two where 1n4148 next to .1k 250 are now changed to 1N4109 on picture, check on the image at the top of the page
  • kardan
    I have marked them
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to Ian-Scott
  • Ian-Scott
    6 of these  should  be 0r3
