Passive Components
Passive Components
Forum Can someone help identifying what this are? I reckon it is an old diod. Need something to replace it with
Join Passive Components to participate - click to join for free!
  • Replies 65 replies
  • Subscribers 105 subscribers
  • Views 10203 views
kardan
kardan over 2 years ago
imageimageimageTUAC TD500-C1 mono amplifier
TUAC TD500-C1 amplifier boardimage
The simple markings on photo does not have the Anode and Cathode marked.
Please reload the page as I have updated the last image.
  • geralds
    geralds over 2 years ago in reply to Ian-Scott +3
    Hi Ian-Scott Just I've rotated it for some readers. Best Regards Gerald ---
  • anniel747
    anniel747 over 2 years ago +2
    Deleted
    shabaz over 2 years ago in reply to anniel747 +2
    Could be.. I thought maybe the color code was brown-yellow-gray, 148, i.e. maybe 1N4148, but I've not seen that before. Anyway, hopefully photo(s) can make it clearer, or some context.
  • kardan
    0 kardan over 2 years ago in reply to Ian-Scott
    Yes, as you can se on the photo in top of the page, 6 of the Wirewound resistor are 0.33ohm the other 2 are 10 ohm. I have now updated bouth photos showing component description so it is not misleading
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to kardan
    Do they measure correct, they do burn out. If the output transistors have gone at some point it can take them with it. I have a TD150 where they had gone and it still worked but didn't sound quite right
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to Ian-Scott
  • Ian-Scott
  • Ian-Scott
  • Ian-Scott
  • Ian-Scott
  • Ian-Scott
  • kardan
    Thanks for the pics, they helps a lot Slight smile I'm doing some measurements, soldering and waiting for several new components..
  • kardan
    It is very hard to find 630v for the 4700pF, but I should be able to use 250v for the 4700pF and 0.01uF as you have. I assume they are replaced earlier on mine.
