Power & Energy
Power & Energy
Blog Converting CO2 into rocket fuel
  • Date Created: 16 Dec 2021 8:39 PM Date Created
  • Views 1703 views
  • elonmusk
  • environment
  • rocket
  • recycle
  • space
16 Dec 2021
Elon Musk tweeted that SpaceX plans to launch a program that collects CO2 from the atmosphere and converts it into rocket fuel. (Image Credit: IJRO/pixabay)
On December 13th, Elon Musk tweeted that SpaceX plans to start a program that focuses on extracting CO2 from the atmosphere, converting it into rocket fuel to power spacecraft. Musk added, “Please join if interested” and said the program “will be important for Mars.” Some of his Twitter followers quickly became skeptical toward the proposal, doubting its viability.
Currently, SpaceX is building rockets for deep-space travel, which could also be used to launch humans to Mars. The company plans on drilling for natural gas in Texas to power its spacecraft and rockets. SpaceX’s Falcon 9 rocket uses kerosene for fuel, which releases carbon dioxide and various other chemicals into the atmosphere.
Previously, Musk announced XPrize Carbon Removal, which rewards $100 million to the best carbon removal technology.  Musk’s initiative to produce rocket fuel could use up a lot of energy to break down the molecular bonds and relies on direct air capture (DAC) technology. An Iceland-based DAC plant started operating in September and could remove 4,000 tons per year from the atmosphere, approximately twice the amount of the world’s previous DAC capacity. It's possible. Although rocket launches put the equivalent of a person's lifetime amount of CO2 in the air, this recycling will at least reduce the impact a little.
  • kkazem
    kkazem over 4 years ago
    If you want to keep up with all the changes and happenings at SpaceX in Boca Chica, TX, look at NASA Space Flight's Youtube channel. They have the best coverage and the best video, including all the launches, engine tests, and even construction of infrastructure there.
