Power & Energy
Power & Energy
Blog Possible Lightning Strike - Tree Leaf Post-Analysis
Toptech-Voices
  • Author Author: shabaz
  • Date Created: 31 Jul 2018 4:03 PM Date Created
  • Views 3530 views
  • Comments 17 comments
  • lightning bolt
  • lightning
shabaz
shabaz
31 Jul 2018
The UK has been having really nice (hot) weather recently, although there was a brief rainstorm, and possibly lightning during periods over the last few days.
We have small pear and plum trees, about 15-20 feet high perhaps. Anyway, the leaves looked really strange today : (
I'm not sure, but I'm wondering if lightning caused it. There are large trees from neighbouring properties that are much taller, and close by. There was some scattering of strange leaves in them too, and generally in the same area, i.e. the entire trees do not seem to exhibit the effect, but it is localised. I can't see any burn marks on the ground, but I have not checked the grounds of the neighbouring trees.
Notice the browned leaves:
More close up:
The pears seem disaffected, but the leaves look toasted : (
A plant at the foot of the tree:
A neighbouring tree:
Scattered clumps of browned leaves in a neighbouring tree:
Closeup of the browned leaves in a neighbouring tree:
Has anyone else experienced anything similar? Do the photos above look like lightning damage, or could something else have caused it?
I'd be interested to hear all thoughts.
    DAB over 7 years ago +4
    Looks more like an infestation, not a lightning strike. If lightning hits the tree, you should see a scar on the bark. Typically, the rest of the tree is unaffected, so you would not see the kind of spotty…
    beacon_dave over 7 years ago +3
    If you want to 'compare trees' then if you head North, there is a tree in the ancient forest at Landmark near Aviemore ( https://www.landmarkpark.co.uk/attraction/ancient-forest/ ) that was hit by lightning…
  • fmilburn
    fmilburn over 7 years ago +3
    I have lived in areas with lots of lightning and trees that were struck had damage where the strike occurred along the trunk to ground. Entire chunks of bark could be blown out. I have not seen leaf damage…
  • ninjatrent
    ninjatrent over 7 years ago
    If lightning had struck the tree, there should be evidence of damage to the tree bark and many green leaves scattered about. I have personally experienced a lightning strike.  It struck a tree near by and reached out and touched me. There was a tingling sensation in my body immediately before it happened. Even part of the charge felt like someone hit me in the head with a sledgehammer.  There was very noticeable damage to the tree bark and green, unburnt and torn leaves everywhere. When I came to, there were still leaves and splintered wood falling. The tree that was initially struck was a Norfolk Pine(has needles) but the deciduous trees in close proximity lost many leaves. The area in which I reside is notorious for powerful thunderstorms. The photos of the pear tree don't  appear to be the result of lightning damage although every incidence is different. Lightning is very powerful and destructive. The evidence would be apparent. The leaves look as if affected by heat and dehydration, maybe a disease but heat is the likely cause of discoloration. If it has been particularly dry season with excessive high temps in that area then lack of water is the culprit. Most trees that bear fruit are very sensitive to environmental conditions. The apple orchards here are not doing so well this year. Fishing has not been good either. I believe as a result of this global heatwave we are experiencing.
    shabaz over 7 years ago in reply to 14rhb
    That's a great idea! I've sent them an e-mail, stating that although I'm not a paid-up member, the engineering community would appreciate their opinion  image
  • 14rhb
    14rhb over 7 years ago in reply to shabaz
    Hi Shabaz,
    I like the notion that the low currents in the upstream charge flow has caused this damage, in the same way that mountain climbers say their hair stands on end and their iceaxes spark etc.
    You could try emailing the Royal Horticultural Society (RHS) who are usually really helpful as they could advise on bugs/virus/dry weather symptoms.
    Rod
    shabaz over 7 years ago in reply to DAB
    Hi DAB,
    You could be right. I haven't seen anything like this before : (
    I've checked the bark, and it doesn't look unusual. Perhaps it is an infection as you say.
    Hi Rod,
    Hehe yeah we do get pear overload each year.. that tree has been there for decades, although it did get severely damaged early in its life, when a chopped tree fell on it. We have a poking stick for the young nephews to use to pull the pears off.
    I've uploaded a video to for a closer look at the trees, I did mess up, those were seeds : ( Nearby is another large tree, and it appears to have browning right above me, when I'm standing next to the pear tree, (I did look at the rest of the tree for similarity - but I still feel it's too much of a coincidence that the the large tree, and the nearby plum tree, have such coloration only near to the pear tree. It could be subjective, maybe I'm only seeing the coloration closest because that's what I'm seeking, despite looking elsewhere on the trees too. : (
    The pear tree overall has extensive damaged leaves. I've got some closeups of a leaf from it..
    More zoomed in:
    Other side of it:
