Power & Energy
Power & Energy
Blog Possible Lightning Strike - Tree Leaf Post-Analysis
Toptech-Voices
  • Author Author: shabaz
  • Date Created: 31 Jul 2018 4:03 PM Date Created
  • Views 3583 views
  • Comments 17 comments
  • lightning bolt
  • lightning
shabaz
shabaz
31 Jul 2018
The UK has been having really nice (hot) weather recently, although there was a brief rainstorm, and possibly lightning during periods over the last few days.
We have small pear and plum trees, about 15-20 feet high perhaps. Anyway, the leaves looked really strange today : (
I'm not sure, but I'm wondering if lightning caused it. There are large trees from neighbouring properties that are much taller, and close by. There was some scattering of strange leaves in them too, and generally in the same area, i.e. the entire trees do not seem to exhibit the effect, but it is localised. I can't see any burn marks on the ground, but I have not checked the grounds of the neighbouring trees.
Notice the browned leaves:
More close up:
The pears seem disaffected, but the leaves look toasted : (
A plant at the foot of the tree:
A neighbouring tree:
Scattered clumps of browned leaves in a neighbouring tree:
Closeup of the browned leaves in a neighbouring tree:
Has anyone else experienced anything similar? Do the photos above look like lightning damage, or could something else have caused it?
I'd be interested to hear all thoughts.
    DAB over 7 years ago +4
    Looks more like an infestation, not a lightning strike. If lightning hits the tree, you should see a scar on the bark. Typically, the rest of the tree is unaffected, so you would not see the kind of spotty…
    beacon_dave over 7 years ago +3
    If you want to 'compare trees' then if you head North, there is a tree in the ancient forest at Landmark near Aviemore ( https://www.landmarkpark.co.uk/attraction/ancient-forest/ ) that was hit by lightning…
  • fmilburn
    fmilburn over 7 years ago +3
    I have lived in areas with lots of lightning and trees that were struck had damage where the strike occurred along the trunk to ground. Entire chunks of bark could be blown out. I have not seen leaf damage…
    DAB over 7 years ago in reply to mcb1
    I had not thought of that, you are probably right.
    I have seen some of my trees get brown leaves when things get too dry and hot.
    So it just might be thermal stress.
    Jan Cumps over 7 years ago in reply to mcb1
    mcb1  wrote:
    As far as I know, lightning is looking fo a discharge path to ground (or is that from ground?) and leaves just aren't going to produce that.
    Cheers
    for lower trees and shrubbery, leaves produce a path when they are wet from rain. That’s one of the reason they survive better. The lightning stays on the external surface.
    mcb1 over 7 years ago
    My pick is sunstroke.image
    I understand the English weather has been unusually hot and they just aren't used to it.
    I suspect you have Fire Blight.
    https://www.youtube.com/watch?v=-qFGSZmzGv4
    Cheers
  • ninjatrent
    ninjatrent over 7 years ago in reply to shabaz
    Hi Shabaz,
    It was a positive  life changing experience. The things taken for granted in life have new meaning.
    The environment is not well. Humanity's dependence on hydrocarbon based energy does not help. Polar ice melts are rapidly cooling the currents in the Atlantic. Past manipulation of the ionosphere (HAARP) is another contributing factor.  The system is trying find equilibrium.
    Lightning strikes produce much of the ozone in our atmosphere. Our atmosphere can repair itself. The most powerful lightning strikes can cause a phenomenon called " Lightning Sprites ". There are some interesting videos on YouTube regarding this subject. It is one of the strangest, and mysterious phenomena in our atmosphere.
    shabaz over 7 years ago in reply to ninjatrent
    Hi Trent,
    Sorry to hear about this, that's frightening. I hope all is ok.
    That's interesting what you say about heat. This years weather has been extreme here, especially the past two weeks, (with govt warnings not to go outside due to the heat!) so it could well be causing more unusual effects to the trees/plants than experienced before.
    There is also very bad air quality - international standards are being exceeded in the UK currently in more than 30 towns/cities. Who knows what damage it is doing to plants/trees : (
