Power & Energy
Power & Energy
Blog Possible Lightning Strike - Tree Leaf Post-Analysis
Toptech-Voices
  • Author Author: shabaz
  • Date Created: 31 Jul 2018 4:03 PM Date Created
  • Views 3534 views
  • Comments 17 comments
  • lightning bolt
  • lightning
shabaz
shabaz
31 Jul 2018
The UK has been having really nice (hot) weather recently, although there was a brief rainstorm, and possibly lightning during periods over the last few days.
We have small pear and plum trees, about 15-20 feet high perhaps. Anyway, the leaves looked really strange today : (
I'm not sure, but I'm wondering if lightning caused it. There are large trees from neighbouring properties that are much taller, and close by. There was some scattering of strange leaves in them too, and generally in the same area, i.e. the entire trees do not seem to exhibit the effect, but it is localised. I can't see any burn marks on the ground, but I have not checked the grounds of the neighbouring trees.
Notice the browned leaves:
More close up:
The pears seem disaffected, but the leaves look toasted : (
A plant at the foot of the tree:
A neighbouring tree:
Scattered clumps of browned leaves in a neighbouring tree:
Closeup of the browned leaves in a neighbouring tree:
Has anyone else experienced anything similar? Do the photos above look like lightning damage, or could something else have caused it?
I'd be interested to hear all thoughts.
    DAB over 7 years ago +4
    Looks more like an infestation, not a lightning strike. If lightning hits the tree, you should see a scar on the bark. Typically, the rest of the tree is unaffected, so you would not see the kind of spotty…
    beacon_dave over 7 years ago +3
    If you want to 'compare trees' then if you head North, there is a tree in the ancient forest at Landmark near Aviemore ( https://www.landmarkpark.co.uk/attraction/ancient-forest/ ) that was hit by lightning…
  • fmilburn
    fmilburn over 7 years ago +3
    I have lived in areas with lots of lightning and trees that were struck had damage where the strike occurred along the trunk to ground. Entire chunks of bark could be blown out. I have not seen leaf damage…
  • fmilburn
    I have lived in areas with lots of lightning and trees that were struck had damage where the strike occurred along the trunk to ground.  Entire chunks of bark could be blown out.  I have not seen leaf damage like that in your photos from lightning but that does not mean it is not possible.  You might check for mites or other small insects under your microscope :-).  Also your local plant nursery may know if it is insects or some kind of wilt.
    If you want to 'compare trees' then if you head North, there is a tree in the ancient forest at Landmark near Aviemore ( https://www.landmarkpark.co.uk/attraction/ancient-forest/  )  that was hit by lightning:
    https://media-cdn.tripadvisor.com/media/photo-s/03/c7/b2/92/landmark-forest-adventure.jpg
    https://mw2.google.com/mw-panoramio/photos/medium/38023009.jpg
    Difficult the see clearly in these photos, but it has a scar running up the entire length of the bark...
