Power & Energy
Power & Energy
Blog Retired EV Batteries Could be Reused as Grid Storage to Cut Emissions
  • Date Created: 7 Aug 2025 6:41 PM Date Created
  • Views 3074 views
  • Comments 10 comments
  • research
  • energy storage
  • ev
  • storage
  • battery
  • grid
  • lawrence berkeley national laboratory
7 Aug 2025
(Image credit: Pexels)
As electric vehicles (EVs) continue to rise in popularity, California is on track to retire millions of EV batteries over the next few decades. So, what happens to all those batteries once they can't power a car? A new study published by researchers at the University of Munster, Fraunhofer FFB, and Lawrence Berkeley National Laboratory shows that reusing retired electric vehicle (EV) batteries before recycling them can significantly help reduce carbon emissions, especially for states like California.
To that end, the researchers provide a trio of models for recycling and repurposing EV batteries in the foreseeable future.
  • Baseline (only 2.5% reused)
  • Recycling-first (100% recycled immediately)
  • Second-use-first (reuse prioritized until storage demand is met, then recycle)
The researchers' findings show that the immediate recycling of all retired batteries could eliminate 48 million metric tons of CO2 by 2050. However, repurposing them for stationary grid storage could raise that number to 56 million tons of CO2. That's an additional 8 million tons of avoided emissions, largely due to delays in reuse, which reduces the need to manufacture new lithium-ion batteries, which consume large resource materials and are carbon-intensive.
The study also highlights a major caveat: by mid-century, battery supply will outpace second-use demand, leading to an oversupply of repurposed batteries. That makes it critical to invest in recycling platforms to avoid bottlenecks and the efficient recovery of valuable materials such as lithium, nickel, and cobalt. While the research focuses on California, it would also benefit the county. States looking to meet clean energy targets can benefit from a "reuse-then-recycle" model, especially when tasking second-life batteries with solar and wind farms.
    DAB over 1 year ago in reply to kmikemoo
    At least the root fires would not leave a load of Lithium compounds that can get picked up by the wind and distributed over a large area.
  • kmikemoo
    kmikemoo over 1 year ago in reply to DAB
     DAB That will be as much fun as a root fire.  I came across one in the early 80's on a training exercise.  We tried to extinguish it with dirt - as you do forest fires.  As we took shovels of dirt from one section, it would expose more and more burning roots.  We finally had to turn it over to the forestry department.  Their plan was to let it burn until the rains of Autumn came.
    DAB over 1 year ago in reply to Fred27
    Just wait until there are spontaneous lithium fires in land fills.
    Not debunked, merely obfuscated because they do not want to admit the truth that and EV is NO better than standard vehicles.
    Emissions are just one aspect of the equation.
    You have to look at the full life cycle, so when you add up all of the numbers, at best it is a wash.
    beacon_dave over 1 year ago in reply to Fred27
    Perhaps depends upon the chemistry / construction ? I suspect it was designed / tested to last to just beyond its original warranty period.
