Power & Energy
Power & Energy
Blog Scientists Design Wooden Floor that Generates Energy
Toptech-Voices
  • Date Created: 13 Sep 2021 5:50 PM Date Created
  • Views 2351 views
  • alternative energy
  • on_campus
  • generator
  • university
  • human powered
13 Sep 2021
The energy-harvesting flooring uses wood with a combination of a silicone coating and nanocrystals, which produces enough energy to power LED bulbs and small electronics. (Image credit: ETH Zurich)
Scientists from ETH Zurich’s Wood Materials Science Center have developed wood-based flooring capable of generating enough energy to power LED bulbs and small electronics. The flooring uses wooden panels with a combination of a silicone coating and nanocrystals to produce a nanogenerator. The wood panels become electrically charged during contact and separation when stepped on via a phenomenon known as the triboelectric effect. That effect is a type of contact electrification where materials become electrically charged after separating from other materials in contact.
When a material is tribo-positive, it loses its electrons and if its tribo-negative, it attracts those electrons. And while wood is terrible triboelectric material, it’s excellent as a building material. To boost wood’s triboelectric effect, the scientists coated a panel with standard silicone that attracts electrons upon contact and placed nanocrystals on the other panel, which loses electrons. When stepped on, the materials flex and contract, producing energy as a piezoelectric generator.
While nearly any wood can be used to create a nanocrystal generator, the scientists found that spruce generated 80-times more electricity than others and is widely used as a building material. The wood flooring prototype used a surface area slightly smaller than an A4 piece of paper, which produced enough power to illuminate those LED bulbs and operate a small calculator as people walked over its surface. The scientists state that the wood flooring could be used for high-end building applications, home automation, powering IoT devices, and sustainable power supplies.
Would walking on this floor be like walking on a trampoline in a slight way? In other words, walking on this floor could be more tiring?
  • colporteur
    colporteur over 4 years ago
    I'm thinking of hiring the River dance troupe for a party I'm throwing. I will floor the garage with this stuff and let them have a her, so I can run the lights in the house.
  • colporteur
  • Catwell
    Catwell over 4 years ago in reply to colporteur
    I liked your idea... researching clubs and energy generation... Found this!!!
    SWG3 unveils plan to install BODY heat system to power its building through body heat
    You have the right idea!
