Power & Energy
Power & Energy
Forum How to design a house PV(solar) power system
  • Subscribers 281 subscribers
  • Views 967 views
Jason
Jason over 17 years ago
As we know ,solar energy is Clean, inexhaustible energy,but how to design a house PV(solar) power system?
    Maybe some information below can help you! And welcome to discussing!
    How to Calculate Solar Energy System Production
    link:http://www.ehow.com/how_4469125_calculate-solar-energy-system-production.html
    How to calculate your solar power requirements
    link:http://www.greenweld.co.uk/data/How%20to%20calculate%20your%20solar%20power%20requirements.pdf
    e14 Contributor over 17 years ago in reply to e14 Contributor
    Hi ZZ,
    Good thought and few I believe have already implemented, below link from google gives a pdf describing home setup on roof with PV solar.
    http://www.energy.ca.gov/reports/2003-03-11_500-03-014F.PDF
    as to designinng is concerned it looks a mere indepth understanding of complete home area power requirements to the heating and lighting circuits you use, and based on that procure PV panels and install with a circuit to monitor , protect and deliver needs.
    Regards
    Tanvir
    hi
    Tanvir!
    Solar energy used in water heating is a mature technology, but for producing electric power it is just beginning. Energy collecting is a difficulty and efficiency is low. And the cost is very high.Waiting for solar panel cost down or this power system can be come true.
    I believe the technology is not the problem!
  • Jason
    Jason over 17 years ago in reply to e14 Contributor
    Hi
    ZZ:
    The structure of solar power system is simple, it make up of solar panel, battery charger, batterry, inverter and load .For solar energy is unstable and discrete, the inverter or the battery charger must has a function of MPPT(maximum power point tracker) to improve the efficiency.And is this system connect to the power-grid, this system must have the function of anti-islanding detection.These two technology are very difficult to deal with.But both of them are important,one is about efficiency and another is safety.
    e14 Contributor over 17 years ago in reply to Jason
    Also,
    Please find below TI solution for same.
    http://focus.ti.com/docs/solution/folders/print/349.html?DCMP=panasia&HQS=Other+EM+pansaia-em091013-en349-eet
    Regards
    Tanvir
