Power & Energy
Power & Energy
Forum Solar Based Battery Charger.....
  • Replies 28 replies
  • Subscribers 284 subscribers
  • Views 5992 views
  • power_management
  • power_distribution
  • power_supply
  • power_conversion
  • power
  • power.power
Muju4mFrnL
Muju4mFrnL over 16 years ago
Please let me know the basic criterias involved or to be considered in making a SOLAR BASED Li-ion BATTERY CHARGER?
    e14 Contributor over 16 years ago in reply to Muju4mFrnL
    Hi Basheer,
    MPPT is implememented basically by continuously monitoring the Solar panel output current and the voltage.It should be an intelligent system preferebly.
    It would be better if you go ahead with the microcontroller application posted earlier.
    You can have a look at the Onsemi application note mentioned in the below link in which they use a discrete MPPT tracker.
    Its based on NCP1294 PWM controller.
    http://www.onsemi.com/pub_link/Collateral/DN06054.PDF
  • Muju4mFrnL
    Muju4mFrnL over 16 years ago in reply to e14 Contributor
    Thank you for your valuable inputs and I will get back to you on this ASAP.
  • Muju4mFrnL
    Muju4mFrnL over 16 years ago in reply to enrico.migchels
    Hi Enrico,
    Considering your inputs i have come across this very new IC from LT it is LT3652. This supports MPPT.
    LT3652 is good IC it can not only support Peak Power Tracking(MPPT) in Solar Applications, can also charge multi-chemistry batteries like Li-Ion/Polymer, LiFePO4, SLA, NiMH/NiCd chemistries.
    Chethanrs
  • Muju4mFrnL
    Thank you for your interest Chetan,
    Well said yes this support almost all the chemistry of  cells/batteries.
    But i have a concern here can we use the same and LT3652 to switch from various inputs like example. Can we have a wall adapter input and a sloar???
  • Muju4mFrnL
    Hi Enrico,
    Any feeback from you would be appirciated inorder to check this can be adopted to redesign for what i had started with?
    HI,
    Yes you can use the LT3652 to switch from Solar input to wall adapter , provided the voltage input to LT3652 is within 4.95V to 32V range .
    Chethanrs
  • enrico.migchels
    enrico.migchels over 16 years ago in reply to Muju4mFrnL
    Hi Mujahid,
    I checked the datasheet of the Linear LT3652 controller. It looks very promising. It has the major benifit of being a hardware controller, so you don't have to be involved with software programming. You have to consider availibility and price of the LT3652 also.
    Lot's of succes!
    Best regards,
    Enrico Migchels
    Power conversion design engineer
    Heliox B.V.
    Best - The Netherlands
    www.heliox.nl
    Mujahid, it is very interesting project, Can I know what kind solar cell or panel you will deploy in your design? I am not sure if there are any formula to calculate the power of solar cell? For example, the battery capacity is 1000mAH, if I plan to complete the charge within 6 hours, what is the suggested solar cell capacity?  This question is also for anyone who has good experience in Solar Power related technology, I expect somebody can help on. Many thanks.
  • Muju4mFrnL
    Hi Austin,
    Thanks for you concern on this.
    If we need to  charge a battery with 1000mAh capacity within 6hrs then a panel with current  output equal to 167mA (1000mAh/6) is required. If the charger/regulator circuit  requires a minimum voltage (as Vin)of about 5V, then a solar panel with approximately 1W  (i.e. 5V*167mA) is required.
